BOOSTED my ego! HeyArms' Supercharger thread
#31
YOU MUST use a wide band O2 sensor/gauge. Tailpipe readings are worthless. I can't believe you have this much invested in time and money and don't even have a wide band O2 gauge installed. If there was a triple facepalm icon I could insert on my phone right now, I would.
#32
Hey, be sure the shop inserts the afr meter correctly into the exhaust. We had problems with our tester 250 reading incredibly high afr's until we realized the nozzle was positioned a little so that it wasnt getting a true reading. Get it way down the exhaust, past that first turn after the rear muffler.
From my experience, the stock ecu will target low 11's in the upper rpms at full throttle
PS. definitely invest in a wideband. I look at mine all the time, to ensure I'm not running on the ragged edge. Weather changes force tuning changes....remember that.
#33
No wideband as of yet because others have been here before, its mostly charted territory. Would i assume my car behaves exactly as others? No. Am i confident enough to assume i can drive conservatively for the time being without major risk? Yes. Do I want to run MAPECU3 to correct inefficiencies? Yes. Would this entail installing a wideband? Yes. Maybe you and others dont agree with the order I am approaching this build, but give it time. My car is one of the most modified cars on the forum, i assure you i wont half-a** the build, and its my first boost project so I have a learning curve, admittedly, but i have talked to nearly all the past and current boosted 2IS'ers before attempting this to instill confidence in what I am doing before following through. I did not blindly go about this.
#34
#35
Just because others have done it before doesn't mean that bolting on the same pieces will yield you the same tune.
Your AFR is the single most critical piece of info on a boosted vehicle if you value a motor still in one piece. Being cheesy on a $200 part when you're playing with a $20k-$30k car is ludicrous.
Go now.. look at AEM wide band gauges. Order one.
You want this: http://www.aemelectronics.com/wideband-o2-air-fuel-uego-gauge-kit-745
#36
Their website is the only place I could find it.
#37
Heyarms i like everything you ve done with the car so far.Pepos is my friend and i tell you the only thing that you cando to this car to make it faster is this.Dont wory about anything.My opinion is to install the meth kit and nothing else.I m thinking it my self but i m not sure yet.BRAVO to you and my friend Elias for making it happen.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#38
Heyarms i like everything you ve done with the car so far.Pepos is my friend and i tell you the only thing that you cando to this car to make it faster is this.Dont wory about anything.My opinion is to install the meth kit and nothing else.I m thinking it my self but i m not sure yet.BRAVO to you and my friend Elias for making it happen.![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#39
Congrats, Adam! Dont worry about 7psi, you're educated enough to have done your homework and talk to all the right people. For what infrequent time you'll be spending at 7psi the stock ecu will not lean out enough to cause catastrophic consequences.
I would encourage you to get a simple coolingmist standard meth/water kit prior to your dyno. You will need the IATs as cool as possible with multiple runs..it's going to heat up quickly and stay hot.
Have fun!
Have fun!
#44
Have fun!
Have fun!
