First post/ R154 Swap
#32
LOVE the wood window regulator. does it have one for the drivers side as well? LMAO!! I have bought cars like that before and just laughed when I came a crossed things like that!
Have fun with the build. looks like you already are! (and knee deep into it!)
#33
#34
hey man nice progress with the car cant wait too see when its done, i was wondering if you could post up a picture on the r154 speed sensor bracket for me, i have a soarer r154 and it has a plug where speed sensor goes, i have a speed sonsor just have to make a fork to hold it on, it would be awesome if you could post one up for me so i could make one as close to factory as possible, thanks
#35
Haven't had much time lately so things slowed down a bit.
but there's some progress to report! haha
Head is out!
Oil pan is off
Now seeing the head gasket I'm more inclined to reuse it. I'm not planning on building this block so if it's not necessary why change it?
The brackets are extremely simple and not really necessary IMO but here it goes.
hope it helps
Next thing to do is to clean everything. Ohh boy..
Head is out!
Oil pan is off
hope it helps
#37
Sorry for the long wait
helped my parents move and got a new job so I've been a little busy
Started on the engine clean up
Decided I am NOT going NA-T on this engine, my buddy is holding a GTE with a getrag for me for a good price, not to mention I still need to get the tranny parts for this swap.
Cleaned the pistons
I was a little concerned about that last piston being a different colour, I thought maybe that piston was running lean or it had been changed?
Got most of the head clean before I pull the valve stem seals
and finally took my exhaust manifold and shifter to get welded, should get rid of that annoying exhaust leak.
Tried out removing the valve springs with a C clamp and a PVC pipe worked fine just have to be careful
pics on that later
Cleaned the pistons
pics on that later
#38
Again sorry for the long wait
The new job is taking up lots of time
Anyway the pcv pipe works but its pretty difficult to use
after about to keepers removed I decided to just buy the tool
Its $64 or so from snap on
Oddly enough the tool is also too big to remove the keepers
but it works great to put the keepers back which is what i was having trouble with
Heres a pic of the old valve stem seals
#40
With the valve stem seals installed it was time to put the head back.
I decided to go with arp head studs and a tt headgasket just in case
got the head on, camshafts and gears went back. Had to clean those camshaft caps! Waterpump and timing belt next.
#41
Got some goodies in for the swap..
got a 13 lb chrome moly flywheel from xtd clutch for real cheap
did a little research and their clutches are iffy but the flywheel is good.
got the vehicle speed sensor along with the clutch pedal assembly, clutch master cylinder and some other miscellaneous items.
everything is going back on the engine!
and keeping me company are my two dogs Leo and Niko
#42
Ohh gosh.
Tried to mate the gearbox to the engine.
Turns out the bell housing was for the 7m.
The guy i picked up the r154 from swore it had the 1jz bell housing and i didn't bother to check.
Ohh well.
Sourced a 1jz bell housing and got those mated.
More updates soon. I'm committed to get this car done asap
Ohh well.
#43
Very nice build! So you're not going GTE and V160 just yet?
I have a question, since you're about to install your R154: it sounds like it's from an MKIII given that you had to replace the bellhousing. Does the tailshaft on yours work with the W58 SC/MK4 mount or only the MKIII Supra R154 mount? If it's the latter, what crossmember solution are you planning to use? I ask because I'm getting ready to swap an MKIII R154 into my car very soon as well.
#44
Haha yeah the gte and v160 are gonna to wait a bit.
I ended up having the tailshaft that only works with the mk3 mount.
So i just made the holes slightly bigger to fit the pattern of the mk3 mount and got longer bolts, washers, lock washers and spacers.
the downside to this is it makes the gearbox sit a bit higher so take that into consideration when you either make the hole on the tunnel or modify the shifter.
