Build Threads Details on Club Lexus SC owner vehicles
Build Thread - Combination of old to current
Old 12-21-12, 08:06 PM
  #31
snomanlex
snomanlex's Avatar
Almost there man. Good job getting the intake welded. Definitely the best way to eliminate pain in the butt boostleaks.
Old 01-01-13, 10:30 PM
  #32
Shadowen
Shadowen's Avatar
My new cup holder came in, as well as some other parts. going to be posting some more pictures when I get a chance. I'm still unpacking from my flight home from D.C.
Old 01-02-13, 07:03 PM
  #33
jwin
jwin's Avatar
Since you have to weld the greddy intake to the lower runners could i use my 2jzge lower runner and weld it to the greddy intake? Or do the ports don't line up that way?
Old 01-03-13, 02:22 AM
  #34
Shadowen
Shadowen's Avatar
I'm not sure on that one. The intake plenum I had came with an adapter for the lower runners. You don't "have" to weld it, but I've been told you should in order to have a proper seal. I don't know if the lower GE runners are the same. Sorry.
Old 01-03-13, 04:45 PM
  #35
SClean93
SClean93's Avatar
Appreciate all the pics
Old 01-30-13, 09:15 AM
  #36
Shadowen
Shadowen's Avatar
So progress has slowed drastically due to me getting married and moving, but here's a few updated pics.
Old 01-30-13, 04:36 PM
  #37
snomanlex
snomanlex's Avatar
Looking very nice. Good job man.
Old 01-30-13, 04:57 PM
  #38
Li Ls4
Li Ls4's Avatar
congrats on the marriage and that motor is looking mighty nice
Old 05-13-13, 03:43 PM
  #39
Shadowen
Shadowen's Avatar
Re-Wiring
Old 05-13-13, 04:52 PM
  #40
BAD954BOI
BAD954BOI's Avatar
Man just looking at the pics I could tell that was a pita smh more power to you cause I don't think my small case of ADD would allow me to be patient enough to put all that back together
Old 05-13-13, 05:06 PM
  #41
Shadowen
Shadowen's Avatar
Most is staying out. All the wiring in the last pic is from the abs, track, speakers, amp, disk player, power antenna, and car phone.
Old 05-14-13, 06:09 AM
  #42
snomanlex
snomanlex's Avatar
Oh the wires. What a pain. Probably one the most time consuming pieces to any build. Glad your making it nice and clean. Keep up the good work
Old 05-24-13, 11:03 PM
  #43
Shadowen
Shadowen's Avatar
New parts. Getting closer to an engine test fit. Also, once the engine is in, I can make the wiring harness.
Old 06-19-13, 02:19 PM
  #44
Shadowen
Shadowen's Avatar
Default Test Fit
Clutch and Flywheel installed. Engine in the engine bay for a test fit. Have to measure and run all the lines and wires. This includes building a wiring harness. I have to route all the sensors and re-run the engine bay wires including lighting. Then I have to turn the turbo and route the charge piping. Figure out throttle cable, coolant and vacuum lines... ETC....
Old 06-19-13, 03:27 PM
  #45
drifterx27
drifterx27's Avatar
Excellent work so far. Looking forward for more pics. Keep going!
Quick Reply: Build Thread - Combination of old to current
