Build Threads Details on Club Lexus SC owner vehicles
2JZ SC300 Rebuild
Old 06-26-13, 07:26 PM
  #151
drifterx27
drifterx27's Avatar
Update:
Got around to messing with the pumps. Had little wiring to do. The car already has 10 gauge wired to the relay. However, these pumps follow too much as of right now. Based fuel pressure is at 4 bar instead of 3, and the fuel regulator can't be adjusted down. So I am gonna have to stage the pumps in order to fix this. So gonna have to run a wire from the AEM to trigger the second pump, and also figure out the relay situation for triggering it as well.
The 485 pump isn't any longer than the 255, it just has a bigger bottom...
Walbro 255 vs 485
Old 06-26-13, 08:58 PM
  #152
jwin
jwin's Avatar
Are you going to put anything between to the two pumps?
Old 06-26-13, 10:20 PM
  #153
drifterx27
drifterx27's Avatar
I am just following what Elite Performance did. Soldered and heat shrank the wires and terminals. I can't fit anything inbetween the pumps and fit it into the tank. Very tight fit.
Old 07-11-13, 08:23 AM
  #154
drifterx27
drifterx27's Avatar
Update:
So the pumps have been in for a while, everything seems to be staying sealed. So that's good. Eugene picked the car up this morning to get tuned with Cam, since I can't go myself for the next few weeks. Cam will have to adjust the fuel map for the bigger pumps, and account for the second pump that is set to turn on later in boost. He should also be setting up my anti-lag too. Hoping for some good things, can't wait to hear what's happening.
Old 07-11-13, 11:50 AM
  #155
kapetajr
kapetajr's Avatar
Are your pumps staged or both on at the same time?
Old 07-11-13, 11:58 AM
  #156
drifterx27
drifterx27's Avatar
Staged pumps. One is on constantly, and the other is triggered by the AEM.
They are texting me the dyno numbers right now. Let's just say my goal has been met.
Old 07-11-13, 12:36 PM
  #157
drifterx27
drifterx27's Avatar
809whp 692wtq!!
Old 07-11-13, 02:07 PM
  #158
gerrb
Super Moderator
gerrb's Avatar
Nice .. congrats ! I was just wondering , looks to me the catch can you have is same as what 97-sc300 and I have . We got ours powder coated . Looks like it is better looking when polished. Does that mean I can get the powder coat removed and get it polished ?
Old 07-11-13, 02:22 PM
  #159
97-SC300
97-SC300's Avatar
yes you can!
Old 07-11-13, 02:45 PM
  #160
gerrb
Super Moderator
gerrb's Avatar
Originally Posted by 97-SC300
yes you can!
Thank you. I will probably get that done eventually.
Old 07-11-13, 03:32 PM
  #161
Suncity915
Suncity915's Avatar
Just read through the entire build, awesome work man. Inspired me big time.
Old 07-11-13, 05:13 PM
  #162
drifterx27
drifterx27's Avatar
Thanks everyone. Took Twinscrewd for a run, and yeah, it pulls for days. My front brakes are done already. The front wheels are bent from the previous owner and so my rotors got warped again. So I need to get replacement front wheels, and then replace the front brakes. I may go to Discount Tire and have them check the front wheels without the tires to see if it is bent?
Either way, BeatZ28 (truestreetcars forum) wants to run me, that's fine with me. I have get this brake issue fixed first, because I don't want to haul *** into a minivan...
Old 07-11-13, 06:25 PM
  #163
99SC42
99SC42's Avatar
Outstanding my friend!!
Congrats to all involved! You guys have done an amazing job, all the hard work paid off.
What was IDC? What's your BFP? How much boost was that?
Again congrats.
Old 07-11-13, 06:30 PM
  #164
drifterx27
drifterx27's Avatar
Again congrats.
Thanks for the compliments.
Boost was 32psi.
Old 07-11-13, 06:32 PM
  #165
drifterx27
drifterx27's Avatar
Base fuel pressure was 43.5. I wasn't there for the tune, but I will find out the injector duty cycle
Quick Reply: 2JZ SC300 Rebuild
