Build Threads Details on Club Lexus SC owner vehicles
2JZ SC300 Rebuild
Old 06-18-14, 07:50 PM
  #286
drifterx27
drifterx27's Avatar
Originally Posted by 8052JZ
Awesome, let us know how it works out.
Package came in. I will test fit them tomorrow and see what happens.
Old 06-19-14, 09:40 AM
  #287
8052JZ
8052JZ's Avatar
nice BTW if you need the boots and springs I found these for 2.99 each new.
Coil Boots
Old 06-19-14, 02:02 PM
  #288
drifterx27
drifterx27's Avatar
Coil Boots
Thanks man, that's one hell of a deal. Just ordered 6. Normally it would be $15 for 1. Got 6 for $30 shipped.
Old 06-19-14, 02:41 PM
  #289
8052JZ
8052JZ's Avatar
No problem. One last thing about them lq9s how do you plan to get tac signal hooked up sense the Tac signal comes from the ignitor? Could you just leave the ignitor hooked up? btw what ecu are you on?
Old 06-19-14, 03:01 PM
  #290
drifterx27
drifterx27's Avatar
From Ali SC3
aem v1 can output its own tach signal via one of the extra outputs, just a few clicks in the software and move the tach wire over to that pin.
I am running AEM EMS V1
Old 06-22-14, 11:51 PM
  #291
drifterx27
drifterx27's Avatar
Well, tried the LQ9 packs. And they do not fit under the manifold. I would need a 3/4" spacer between the upper n lower manifold to possibly make them work.
So now I am thinking if I should do the intake manifold swap, or try and get a spacer made and see if it gives me enough clearance.
I think I would want the spacer as it would be less work.
Also, I wonder if I could get the vvti coil packs to work? Is there a way to test them and make sure they are outputting 100%?
I need suggestions...
Old 06-23-14, 08:53 AM
  #292
8052JZ
8052JZ's Avatar
I believe Jason at Rosario Racing makes the spacer for the NA intake manifold... google em..
Old 06-23-14, 01:48 PM
  #293
Toyboxx
Toyboxx's Avatar
I've also heard of people running 1ZZ coilpacks with the same if not better results then the LQ9's.
Check this out, some info on 1ZZ Coils
http://www.supraforums.com/forum/sho...ket-coil-packs
Also got a buddy local to me that is running 1ZZ coils on ProEFI 128 on his 1JZ making 700+ to the wheels on stock head, & block.
Talk to him, he is pretty knowledgeable with the whole setup.
http://www.supraforums.com/forum/sho...re!&highlight=
Old 06-23-14, 04:36 PM
  #294
drifterx27
drifterx27's Avatar
I talked to him. He makes spacers for $100. I told him I would need a 3/4" spacer. I want to try another set of VVTI coil packs before I go with the spacer.
Old 06-25-14, 06:19 PM
  #295
drifterx27
drifterx27's Avatar
I am almost sure now that the vvti packs I have are no good, which sucks since I had bought them off someone on the forum. I ordered another set off of a JDM VVTI motor on ebay. I will try these out and see what happens. I saw another SC300 that was running the VVTI coil packs at 33 psi 834whp. That's right around where I will be, and so I don't see why I am having an issue unless the coil packs are bad.
If I have to spend anymore money, I will just get the spacer I need and mojo harness for the LQ9 packs.
So I might have some brand new AC Delco LQ9 packs for sale, if I can get the VVTI packs working properly.
Old 06-26-14, 01:53 PM
  #296
stevegrizz
stevegrizz's Avatar
Just remote mount the lq9's... not sure what the problem is!
Old 07-10-14, 11:14 AM
  #297
BAD954BOI
BAD954BOI's Avatar
Update on the coil pack issue
Old 07-10-14, 11:42 AM
  #298
drifterx27
drifterx27's Avatar
I ordered a HKS DLI for a supra to boost the coil pack output. It's a new unit, which I was lucky to find.
I had the exact same issue with these vvti coil packs as I did with the other set of vvti packs I had before. So the issue isn't the packs. It must be not enough power. So I am gonna boost them with the DLI and see if that fixes it. I don't want to do the LQ9 because of the work I would have to do. I will probably sell them off.
Old 07-10-14, 12:14 PM
  #299
8052JZ
8052JZ's Avatar
I have the same issue with the vvti coils. Anything about 22psi it starts to break up and cars starts to buck a little. Waiting for the aem coils to come in and hopefully that fixes the issue.
I would try an put those lq9s in rather than mess with a DLI.. a bit more work but much better in the long run. specially when your in the 800hp range
Old 07-20-14, 09:00 PM
  #300
drifterx27
drifterx27's Avatar
Installed the DLI and it helped. I am able to hit the 28psi now, but it's not enough. So it looks like LQ9 conversion is next. Going to order the harness from Mojo tomorrow and the spacer from Rosario Racing.
So if the spacer is good enough, I will have 2 sets of VVTi coil packs and an essentially new HKS DLI for a Supra for sale.
Quick Reply: 2JZ SC300 Rebuild
