2JZ SC300 Rebuild
#47
Still have to:
- Get lines made for the catch can
- Install the connectors for the ID2000 injectors into the harness
- Mail out flywheel
- Order clutch
- Get fittings welded onto valve cover and intake pipe for catch can
Also, a video of my car that popped up recently
#49
Update:
Sent the flywheel out to get resurfaced in Texas. Sold the 240 and M5, which I am very happy about. Then I ordered all the fittings and lines I need for the catch can setup. I will be doing silver fittings with black stainless lines. I prefer the lines to be hidden, as the normal silver lines stand out too much for me. Also the crimpers I needed for my injectors connectors is here, so I can start that too. And finally, talked to Sharp Hydrographix and I may get the valve covers done (still deciding on color scheme).
So a break down of what's left:
- Wait on flywheel to come back
- Decide to either order clutch or pay credit card
- Redo injectors connectors for ID2000
- Remove injector resistor box and solder wires
- Get valve covers and intake pipe welded and tapped for -10 an fittings, when the fittings and lines show up
![](http://truestreetcars.com/forums/attachments/projects-builds/41659d1366330238-2jz-sc300-build-ss_lines_black_picture.jpg)
#51
It's $40 and they know what they are doing with dual mass flywheels.
#52
You may wanna rethink you clutch selection buddy.
I had that clutch on my 6speed , it's very aggressive..
You have have 2 options on the Pressure plate selection , it's either RPS or ACT which are very very heavy.
it's the same as the WOTM clutch aka the Arizona clutch Heavy Pressure plate with except the hpf comes with a feramic disc which is great and holds the power.
gl with the project.
#53
#54
It will hold the power with no problem but it's very harsh, pedal is very very stiff and You will trash that built engine.
Whatever you do do not get act, rps single or spec all of them use the stock toyota PP but when they modifiy it they use a duall diaphram so the pedal is very very stiff , It will hold the power you you will distroy your trust washers in your block .
#57
Clutch masters Single is great clutch.
SouthBend are amazing.
Clutchmasters Twins is badass will hold 900wtq and 1100whp , if you don't wanna spend RPS CC money.
RPS CC is very nice, OS giken iS also a great clutch.
I have no experience with Competition on the V160.
With all these clutches your pedal will feel like bone stock![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
How much power are you shooting for ?
GL
GL
