My Aristo Single Turbo Project
#46
The turbo is only a 62.5mm inducer - the surge portings make the intake look a lot bigger. I went for a turbo that will give a good balance of response and power delivery.
#47
Got pretty much the rest of the bits now!!
320LPH Fuel Pump:
![Name: 4E4B7414-7B09-40A9-9965-AA1BBCCEBFE3-4073-0000034B2EE47099_zps80affd01.jpg
Size: 73.7 KB](https://www.clublexus.com/forums/attachments/build-threads/462775d1501791993-my-aristo-single-turbo-project-4e4b7414-7b09-40a9-9965-aa1bbccebfe3-4073-0000034b2ee47099_zps80affd01.jpg)
Tomei Type-L Fuel Pressure Reg:
![Name: 63A74A4D-3718-482C-8326-766BC9BBA46A-4073-0000034B085E8E62_zps05b42dc1.jpg
Size: 295.5 KB](https://www.clublexus.com/forums/attachments/build-threads/462776d1501791993-my-aristo-single-turbo-project-63a74a4d-3718-482c-8326-766bc9bba46a-4073-0000034b085e8e62_zps05b42dc1.jpg)
Valve Springs:
![Name: 603402C8-5013-4EFC-A25F-1207B6A1EAFC-4073-0000034AF6501A08_zpsa7897656.jpg
Size: 292.0 KB](https://www.clublexus.com/forums/attachments/build-threads/462777d1501791993-my-aristo-single-turbo-project-603402c8-5013-4efc-a25f-1207b6a1eafc-4073-0000034af6501a08_zpsa7897656.jpg)
TiAL recirculated BOV:
![Name: 4CD5D8F0-C4B7-477C-B60A-66F6466EC53F-4073-0000034ACD137CE3_zpsab511255.jpg
Size: 300.5 KB](https://www.clublexus.com/forums/attachments/build-threads/462778d1501791993-my-aristo-single-turbo-project-4cd5d8f0-c4b7-477c-b60a-66f6466ec53f-4073-0000034acd137ce3_zpsab511255.jpg)
Big *** K&N filter:
![Name: 4C86BFEF-E49E-47CF-B09B-5BC18A5861A9-4073-0000034AC1C25B73_zps382ec156.jpg
Size: 104.1 KB](https://www.clublexus.com/forums/attachments/build-threads/462779d1501791993-my-aristo-single-turbo-project-4c86bfef-e49e-47cf-b09b-5bc18a5861a9-4073-0000034ac1c25b73_zps382ec156.jpg)
HKS 264 intake and exhaust cams (only bothered to unwrap one)
![Name: 6FDC1292-4710-497F-8DA7-883D02A2DF94-4073-0000034AB3EFD302_zps08d345f8.jpg
Size: 112.9 KB](https://www.clublexus.com/forums/attachments/build-threads/462780d1501791993-my-aristo-single-turbo-project-6fdc1292-4710-497f-8da7-883d02a2df94-4073-0000034ab3efd302_zps08d345f8.jpg)
HKS S-Type Intercooler (600mm x 301mm x 65mm)
![Name: D07EF589-9938-4007-A613-2DF5513A163C-4073-0000034A8D2150C8_zpsbaca0b38.jpg
Size: 281.1 KB](https://www.clublexus.com/forums/attachments/build-threads/462781d1501791993-my-aristo-single-turbo-project-d07ef589-9938-4007-a613-2df5513a163c-4073-0000034a8d2150c8_zpsbaca0b38.jpg)
![Name: B08B1286-A1B6-46C7-BFD2-1C06A2D9E21E-4073-0000034A9DFE48A5_zps967f4ea6.jpg
Size: 96.0 KB](https://www.clublexus.com/forums/attachments/build-threads/462782d1501791993-my-aristo-single-turbo-project-b08b1286-a1b6-46c7-bfd2-1c06a2d9e21e-4073-0000034a9dfe48a5_zps967f4ea6.jpg)
Misc parts, engine + trans mount, water pump, cambelt, fuel filter, gaskets etc.
![Name: 4D8F0C87-5606-4B5B-9B8D-934D9680CFA8-4073-0000034B17E4B769_zps1d88ead2.jpg
Size: 237.0 KB](https://www.clublexus.com/forums/attachments/build-threads/462783d1501791993-my-aristo-single-turbo-project-4d8f0c87-5606-4b5b-9b8d-934d9680cfa8-4073-0000034b17e4b769_zps1d88ead2.jpg)
ECU is only around 10 days away, and my injectors have arrived and are with the tuner.
Getting close!!
320LPH Fuel Pump:
Valve Springs:
Big *** K&N filter:
Getting close!!
#51
Interesting... as I had the 6 links and the rear mid brace on order, and the supplier cancelled on me!!
#56
What upgraded did you do to the trans? Or did you buy a fully built trannys?? And did you have any probs mounting up your mani with the steering rack in the way?
When I get my aristo ill be running borg Warner sprag clutch kit, new kolene frictions and steals, BL/Titan 3400/3500 stall , shift kit and a tranny cooler! And either run my gt42r or just upgrade the stock twins to dual gt28s, and run it on hks fcon vpro 3.24 with hks evc6! Of course ill do a trd LSD with dual walboros 255 and id 1000cc inj.
#59
Mani was custom built on a JZS161 they had in the shop.
IMO - don't bother upgrading the standard twins, I looked into it, wasnt worth it for the expense and gains, I have heard reliability isnt great either - just go single.
Do you already have the 3.24 ECU, as the just released V4.00 integrates full VVTi control, and has an internal boost controller.
#60
Yea I already have the 3.24! I picked it up for a decent price but if the 4.0 isn't to much more I can probably opted for that but ill see..
Well I have alot of people telling me to keep the gt42r and dump the twins. But thts a big turbo I have and would need my tranny built to hold some nice power. As far as aristo tranny it can only hold around 400hp from I have been looking up, unless someone's builds it...
