Build Threads Details on Club Lexus 2GS owner vehicles
My 2jzgte swap
Old 08-12-13, 01:32 PM
  #61
gambino19
gambino19's Avatar
nice work bro intercooler looking good.
any other mods since last post
Old 08-12-13, 03:59 PM
  #62
vbieds
vbieds's Avatar
Originally Posted by 0flav85
I have a question about the swap, are all models required to move pins on the gray plug, because I didnt have a shift lock when i turned it on. the car runs and everything. I have several lights on and I know i have to pull the vcs bulbs but my windshield washer light is on but I topped it off, my oil light is on and when I go over a certain rpm my check engine comes on and stays on until I shut off the car and its off again when i turn it back on also my ECT starts flashing when my check engine light goes on. once the check engine turns on. the car shifts early and down shift quick when i get off the gas. It seems to bog if I floor it and when that happens it feels like im just making noise and not really going anywhere like a civic lol. I havent run my tach wire yet so cant really reference any rpms but if i floor it and it reaches a certain rpm it will bog and i wont accelerate. Are these the simtons of limp mode and if so wich wires do i move to and where do they go on the plug. I still need to run my tach line will that fix any other lights on the dash or just make the tach work? And do i just cut and soder the wire to where it goes on the body plug? thanks again for the help.
That sounds just like limp mode, which I just went through with the intercooler. Check all of your piping and connections. My issue was that I had the cheap keepers on. I had to order t clamps to keep the piping together.The car did not like keeping the piping together at full boost. around 14psi. The car sees solid boost and feels as if it is much quicker to respond.
I cannot diagnose your exact symptoms, as It could be anything. Start with the small things, check then double check. I was experiencing those symptoms before (if you read the other pages ) and I had two bad and leaking turbos.
I didn't cut or solder the wire. I pulled the wire from old the GE harness, and placed it in the spot where it is blank on the GTE one from the ecu to the igniter. Another GTE thread covered it completely, that's where I got the info.
Old 08-12-13, 04:03 PM
  #63
vbieds
vbieds's Avatar
Just ordered a walbro pump, APEXi S-AFC II, and a APEXI AVC Type-R. Still undecided about injectors and an intake.
Old 08-16-13, 03:58 PM
  #64
0flav85
0flav85's Avatar
thanks man, i was talking about where on the body plug do you connect the wire that you put in that empty spot on the ignitor plug. also what fixed your lights on your dash: washer fluid, oil and lamp out light?
Old 08-17-13, 04:32 PM
  #65
vbieds
vbieds's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Its going to be the yellow and black wire from the white plug pictured. Im not sure about your lights, I had no lights on except vsc and trac and the bulbs were removed.
Old 08-19-13, 08:55 AM
  #66
0flav85
0flav85's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Thanks man I did that and my lights went out except for vcs. Now I got another problem. I ran out of gas the other night on my way to the gas station the fuel gauge said I had a quarter tank but it was really empty, I was trying to figure it out, looking for vaccum leaks and checking my sparks. The car started then died a few seconds later. I went home and remembered about the fuel gauge being off for everybody's swap so I put fuel the next morning and she started up so I went to the gas station and toped her off. On my way back the car started sputtering again as if I had no fuel, I pulled over and it shut off, it would turn on run for a few then die and every time I started it up it would die faster. Came back a few hours later and it started up and drove it home. After being on for 12 minutes it the idle starts to drop then it dies and again every time I turn it on I shuts off faster, I wait a few hours and turn it on, it last for about 12 minutes the. Does the same thing. Do you think there is air or something in my fuel lines or is it my pump taking a ****, I still get check engine when I drive, do you think I have to repin the gray plug that's next to the orange plug. I'm going to test my fuel pressure and see if my pump is going bad, do you know if 2jzgte motors have a place to plug in the fuel pressure tester or will I have to splice the fuel line with the tester
Old 08-25-13, 01:29 PM
  #67
vbieds
vbieds's Avatar
Damn, that's a tough question. I have never run out of gas in any of my cars, and the only two times I have had a sputtering issue in the lex was due to having the intercooler lines blow or pop off. My gauge is off an 1/8 th of a tank, but have never had any issues because I don't run the fuel that low.
One of the things I did was to change out my pump to the aristo pump that came with the swap. I don't know if your pump is bad or was on its last leg before the swap. I don't have any lights on in the car, but they all illuminate before startup like they should.
I don't know if/where you can plug the tester in. You may want to look in the forums or take it to a Toyota tech for diagnosis.
Old 08-28-13, 02:07 PM
  #68
0flav85
0flav85's Avatar
it works now, i think it was just air in the lines. I still gets check engine light around 3,000 rpm and shifts weird and the ect light starts flashing. I think its a speed sensor but i dont have anything to read engine codes.
Old 08-29-13, 06:15 PM
  #69
vbieds
vbieds's Avatar
Glad you got part of it fixed. I found that working on it and fixing these small things make it that much more fun to drive.
Old 09-01-13, 08:18 AM
  #70
0flav85
0flav85's Avatar
your right brother about that lol. I finally got it. the vss connector towards the rear was disconnected and broken so replaced it with the one from the gs. Now it runs like a champ. Now I can worry about my single turbo upgrade. and I might go manual too.
Old 09-12-13, 01:35 AM
  #71
gambino19
gambino19's Avatar
Default good look
i like the mushroom style intakes...injectors matter if you are going to run single or not if your gonna keep the twins 1000cc more than enough .....gl on the piping ill post pix when its installed!!!!
Old 09-15-13, 08:43 PM
  #72
vbieds
vbieds's Avatar
No problem man, glad I could help someone out! I cant wait to see the car!
Old 09-16-13, 08:18 AM
  #73
blacksedan
blacksedan's Avatar
I'm from Houston and I've been kicking around the idea of doing this swap but keeping it factory GTE with exception of an intercooler. If I find a complete swap, (motor, turbos, trans, ecu and wiring), what all else is needed to complete the swap?
motor mounts?
do I have to upgrade fuel pump?
anything small, additional?
wire harness conversion kit? (I have a '98)
Also, from reading some other threads, some were saying you only have to connect 1 additional wire if you have a 98-01, which I'm presuming is what you were talking about up above a few posts. This is if you're disconnecting the GE ecu and replacing it with the GTE's ecu?
  #74
Trevstuh
Trevstuh's Avatar
I just may be doing this swap, since I am almost at 242k on my motor.
Old 09-16-13, 07:29 PM
  #75
0flav85
0flav85's Avatar
motor mounts?
No mounts needed use the one that comes with the motor, you need the front half of the drive shaft from a toyota jzs161 aristo, you need a sard jpk ( jet pump killer) and run a fuel return line, for wiring you just need to run the green tach wire to the igniter plug and u can use the one from the gs. Check all you plugs and connectors cus some might be broke just replace it with ones on gs.
Quick Reply: My 2jzgte swap
