After nearly 2 years at 350rwhp... its time for a change.
#91
do you have a wideband in, how rich are you at idle and cruise? if you need help with the o2 I can give you a hand this weekend I should have my car back on the road by then as well and minus an afc.
#92
Yeah, ill be over at the garage on Saturday. Still just tweaking and fine tuning.
Gonna install the GTE coils and igniter
Pull the cluster and pull some of the bulbs out... Trac, trac off, OD off... LOL
Need to wire in the relay for the A/C
Wanna double check that my map is good
Have to adjust the tps
Change tranny fluid
Trying to get around to repainting my calipers too.
Change tranny fluid
#93
So it looks the same as it has, but in this pic, it is capable of running and does... lol
Been driving it for just over a week now and it does need some tweaking
Gonna do the things on my list this weekend and see how that goes.
Once school starts and i get the rest of my tuition money, Im gonna get my 4 inch exhaust installed.
4 inch downpipe to 4 inch straight pipe all the way back
Then once its running right, gonna repaint the calipers I think... Im feeling a Hot pink with glow in the dark clear and prism flakes.
I also think Im gonna grab a spare auto and build it up til I get around to putting together my manual swap.
#96
#97
Nope, dont feel like messing with it. This one works fine until it doesnt. I may build another stock one for a backup, but Im doing a manual swap one of these days. Just have to buckle down and buy the parts.
The tranny cooler is in line with the radiator one as well. its hanging on my AC condenser. Its pretty big, and ive not had any issues with my tranny really. Slight slippage in first but locking the line pressure cable took care of that.
#101
Cleaner now, this is the setup with GTE coils... not that you can tell. LOL
Vise grips are gone too.
Turbo drain is leaking at the turbo.... FML... have to pull that out and fix it.
Still running rich as hell too.
#103
Its just from pulling the turbo off and putting it back in 100 times. Not a big deal. I just have to reseal it.
I think I either have a bad map or... im not quite sure what the problem is. Im gonna look into it more today.
