93 SC300 1JZ swaparoo
UPDATE:
so I finished the wiring last night! yay dont want to do that again :/
Today got loads done, put clutch and trans on, got everything torqued, and dropped it in. heres some pics
Here is the exact amont of string needed to put in cyl 1 to lock it to get the crank pulley to 239 ft-lbs, which I did with my super awesome torque wrench
this is my partner in JDM engine swapping crime (he has a SR20VE swapped 200sx built for auto-x)
awesome lo-res pic of his car
here is the engine about to go in
and its in!!!
I still need to do the heater core lines, intercooler, and exhaust, but other than that its lookin good!
and its in!!!
UPDATE:
So today I got all the pipng figured out and buttoned her up, and.........ITS ALIVE MUAHAHAHAHAHAHaHA
all is well except there is a miss at idle and stuters around 3k rpm, any advice on this would be greatly appreciated.
pics for clicks
pics for clicks
heres a link to the video, I dont know how to embed FB vidoes, otherwise I would have
https://www.facebook.com/photo.php?v...18845403083394
UPDATE
well the whole swap is done and driving great, the stutter was due to improperly gapped plugs and some cracks in the coils. After fixing those issues it runs amazing, feels better than when I was NA-T for sure.
Ill post a better video once my exhaust comes in.
Hey man the swap looks perfect good job
I'm currently in my garage dropping my 1jz in right now but I have question
The plug that's on the power steering rack on the driver side right before the motor mount where is that connector at? Some folks say its behind the alternator I'm dumb and can't locate it did you find it?
Tia
Tia
Ok cool, because of the dumps its running around 14 psi, with good afrs, ill leave it there. Are there any considerable gains to be had getting it dyno tuned with an afc neo?
Thanks kez! I need some elp understanding which plug you are referring to, mind helping me? pics or something?
Tia
Tia
