Build Threads Details on Club Lexus 3GS owner vehicles
Diesel350 build thread
Old 04-03-13, 12:46 PM
Diesel350
Diesel350's Avatar
Originally Posted by sprtent
Doesn't hurt to ask. Tell them you just bought your Lexus and will try to build a good service relationship with them and will let them service your car. With 37k miles, you might still have the original pads on, and should be replaced anyways.
I don't know how you checked the service records. I usually do through Lexus.com website. Register your car and VIN through the "Owner Resource" feature, then under "service history" you should see what was done and/or if your car need any recall/TSB done.
Hope you enjoy the car.
Thanks, I did check the service records through the Lexus website but did not see any TSB's or recalls that needed to be done.
Old 04-05-13, 04:50 PM
anthrax144
anthrax144's Avatar
Originally Posted by Diesel350
Thanks I'll check it out. So this works with the IPhone 5 even though it says its only compatible with Blackberry phones?
Yup, works flawlessly. I've had one for a few years now, worked perfect on my 3G, 4 and now iPhone 5.
Old 04-06-13, 10:19 AM
MelYW
MelYW's Avatar
My puddle lights turn on as I walk up to the car. Doesnt work everytime though. Be aware of the cam gear overhaul TSB. Being in FLA, dash rattles shouldnt be as bad.
Enjoy the ride.
Old 04-06-13, 12:23 PM
Diesel350
Diesel350's Avatar
Enjoy the ride.
What is the cam gear overhaul TSB? Is this something I will notice if it needs to be done? Should I mention this next time I am at the dealer?
Old 04-07-13, 11:05 AM
MelYW
MelYW's Avatar
Search it across this forum. Did you get a list of TSB's done on the car?
In some cars (including mine) the car would give a horrid grinding sound at start up. It is a major overhaul to get it corrected...paid for by Lexus/Toyota.
They also increased the warranty coverage of the drive train to 100,000 miles....as for the year extension I cant remember.
Old 04-07-13, 12:07 PM
Diesel350
Diesel350's Avatar
Thanks I looked it up and I think I may have that issue. I looked at the services done and I did not see any TSB's done, I will have to wait and go to the dealer to see if they had done any TSB's to the car.
Old 04-10-13, 06:25 PM
Diesel350
Diesel350's Avatar
Ended up getting window tints 15% all the way around and did a full wash, claybar, 2 step polish, sealant on the car. While the polish I used certainly gave the car a nice glossy look and cleaned up the car there are still alot of imperfections and scratches on the paint. I'm going to have to go with a heavier polishing compound and a much more aggressive pad to see if I can get more correction. Just not happy with the results I got.
One side untouched and the right side was after applying Meguiars 105 Cut polish and Meguiars 205 Finishing polish.
Roof
Old 04-10-13, 06:36 PM
TexasTaco
TexasTaco's Avatar
Welcome to having an obsidian black lexus, lol.
Old 04-10-13, 07:46 PM
ibidu1
ibidu1's Avatar
Obsidian is tricky! M105 M205 cleans it up nicely, but the paint is just super soft and scratches easily. I try to stay away from washing the car and I lightly use a california duster. Also you may want to finish off with a good long lasting sealant, expect to use lots of waxing with this car lol
Old 04-11-13, 08:33 AM
MCCR
MCCR's Avatar
congrats on the new Whip. I just bought an 07 GS 350 RWD-blue, not sure the actual paint code. one thing you can do if you don't want to wash the car very often is to go to a self service car wash and use the spot free rinse to remove dust, bird crap etc. then, instead of drying it with a micro fiber towel, just hop onto the freeway and let the air dry it, after this just get some meguries detail spray to remove any water spots left over.
Old 04-11-13, 09:22 AM
sprtent
sprtent's Avatar
Diesel350,
If later on a heavier polishing compound still doesn't do it, I recommend a light path of wet sanding with 2-3000 grid paper, then rubbing compound, polish, sealant, and wax. The claybar only clean stuff on top of the paint, doesn't help much with scratches.
But to be honest, you did a lot of work already to the car and it looks good already. Hope you have time enjoy driving your car as much as working on it.
Old 04-12-13, 06:27 PM
Diesel350
Diesel350's Avatar
Thanks to Anthrax on can now listen to Internet Radio through my Iphone 5 via the BlackBerry Remote Stereo Bluetooth Gateway. As you can see it's tiny and fits perfectly in the console and it sounds just as good if not better then the radio.
Old 04-12-13, 06:44 PM
c-low
c-low's Avatar
wow looks really good! glad you got all the scratches fixed!
Old 05-16-13, 04:51 PM
Diesel350
Diesel350's Avatar
Noticed a bunch of scratches on the pillars so decided to polish them up.
Before:
After:
Old 05-16-13, 05:04 PM
anthrax144
anthrax144's Avatar
Working out for you? I love mine and don't think I could have a car without that function now.
Quick Reply: Diesel350 build thread
