Build Threads Details on Club Lexus SC owner vehicles
My 97 sc300 NA-T 6 speed AEM with LQ9 coils build
Old 04-29-13, 02:26 PM
  #46
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
The motor looks very clean man. I am anxious to see it installed and up and running. Glad you figured out the motor mount issue as well.
Old 04-29-13, 02:29 PM
  #47
jwin
jwin's Avatar
I haven't really figured it out. I think I'm going to install the mounts from my 97 motor unless someone has some 93-96 supra mounts they wanna sell me.
Old 04-29-13, 03:01 PM
  #48
gerrb
Super Moderator
gerrb's Avatar
jwin - I can sell you those motor mounts if you want them . I don't need them for now .
Old 04-30-13, 08:03 AM
  #49
nuturf87
nuturf87's Avatar
Originally Posted by jwin
I will not be running the Tt oil pump because it provides too much oil Pressure for a 2jzge motor. I don't want my front main seal to leak because of the excessive oil Pressure. I don't know of a 2jzge oil pump that has the holes to mount the 6 speed tensioner. I might figure something else out to keep the belt on. I brought a new 97 sc300 oil pump which has a spot for a crank sensor.
Gotcha.....Everything looking good . Keep us posted!
Old 04-30-13, 08:45 AM
  #50
8052JZ
8052JZ's Avatar
the VVTi oil pump off an is300 is the perfect oil pressure for the GE unlike the GTE. IT also has the crank sensor mount and the 6spd tensioner holes threaded....
Old 04-30-13, 09:47 AM
  #51
jwin
jwin's Avatar
Dang it. Lol. Do you know what year? Would it be the 5 speed is300?
Old 04-30-13, 10:37 AM
  #52
8052JZ
8052JZ's Avatar
Doesn't matter as long as its from a vvti GE motor. I found one on fleebay for under 100 bucks genuine aisin oil pump. Actually got it for 77 after ebay coupon and ebucks Driftmotion also has them for 105 I believe.
http://www.ebay.com/itm/AISIN-OPT-071-Oil-Pump-/310429708026?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AIS300&hash=item48470d6efa&vxp=mtr
Old 04-30-13, 10:41 AM
  #53
jwin
jwin's Avatar
I just brought a new one and installed it. I probably buy that one for my next motor
Old 04-30-13, 08:27 PM
  #54
lilSCsteve
lilSCsteve's Avatar
it's coming along bro! Now go ahead and finish this thing man! So I can copy ur build! lmao
steve
Old 04-30-13, 08:36 PM
  #55
jwin
jwin's Avatar
its taking forever. Waiting for the motor mounts i got from GERB to come in. Then I have to modified the turbo manifold for 38mm tial. I hope it will hold for enough boost from a bw s366 with about 20psi or should I go bigger?
Old 04-30-13, 10:04 PM
  #56
NaadiSC400
NaadiSC400's Avatar
Nice I am also beginning my 6speed swap with a v160 trans and TRD LSD to my v8 SC400 looking forward to seeing your progress
Old 04-30-13, 10:40 PM
  #57
lookEVO
lookEVO's Avatar
tial 38mm will be plenty. dont sweat it
Old 04-30-13, 10:51 PM
  #58
jwin
jwin's Avatar
cool. I am waiting for the mounting flange to come in to weld it on the turbo manifold.
Old 05-03-13, 12:17 AM
  #59
jwin
jwin's Avatar
How to install diff bushings
1. Removed your rear differential from your car
2. Take a plumber touch (25 bucks from home depot) and heat the metal bushing where the bolt goes through up from the inside of the bushing. Once the rubber gets soft you can hit it out with a hammer. You will need to reuse these so don't mess them up.
3. Now take a chisel or punch and slowly hit the bushing out (you should see a little lip of the bushing sleeve on the differential ear use to hit the sleeve out). Make sure you go around the bushing sleeve and hit it out evenly. You don't want to have it **** sideways because it will make it harder to come out. It doesn't take that much force for the sleeve to come out. I did it with a rivet gun (air hammer) with a chisel attachment.
4. Install the poly bushings and slide the metal bushing that you beat out earlier into the poly bushing.
Total time - 10 mins.
The bushing sleeves after they were taken out.
Finished Diff with poly mounts.
Modifying the CX turbo manifold with a tial 38mm flange.
I work up early today and got some work done on the car. I removed the driver side axle so I can install the TT 6 speed drive axle. The driver side axle is 547.5 mm (21.555 inches) long which is measure from mating surface of the drive axle to the diff all the way to right before the spline right after the ABS gear. The passenger side should measure 598.5mm (23.602 inches). The picture in the TRM is not exact so if you have both the axles one should be about two inches longer than the other. I have one TT axle that came with my swap. I have been searching all day for the length on the axles. Hopefully the axle that I have is the shorter driver side TT axle for the 6 speed. I am pretty sure you can use the Sc300 passenger axle with a supra TT 6 speed diff, but I don't think you would want to as the TT axle are way beefier. I will be installing the diff when I get off work in the morning hopefully all the parts that I have are correct.
Old 05-03-13, 07:07 AM
  #60
jwin
jwin's Avatar
Final installation of the turbo manifold. The oil drain is posing a problem. I don't have enough room for the AN fittings. I am really leaning towards making a hard pipe. What has other people done to fix this issue. I don't want to clock the turbo too much because I'm worried the turbo won't drain properly.
Beside that issue I'm pretty happy with the wastegate placement. I was measuring the sc300 driver side axle and its only .2 longer than the supra 6 speed axle. Will that .2 inches make that big of deal?
Quick Reply: My 97 sc300 NA-T 6 speed AEM with LQ9 coils build
