Build Threads Details on Club Lexus SC owner vehicles
My 97 sc300 NA-T 6 speed AEM with LQ9 coils build
Old 05-03-13, 10:38 AM
  #61
nuturf87
nuturf87's Avatar
Originally Posted by 8052JZ
the VVTi oil pump off an is300 is the perfect oil pressure for the GE unlike the GTE. IT also has the crank sensor mount and the 6spd tensioner holes threaded....
LOL, i forgot that the vvti ge oil pump has a crank sensor mount.....
Old 05-03-13, 08:10 PM
  #62
jwin
jwin's Avatar
http://www.ebay.com/itm/Turbo-Oil-Drain-Return-Pipe-Kit-Garrett-T3-T4-T60-T61-T04B-T04E-5-8-Hose-/151028701019?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item232a03175b#ht_1341wt_932
I brought this turbo drain tube and will probably make it longer if needed. My original plan was to use a -10an hose but I am afraid it might touch the manifold or melt because of the heat. I took a picture of the area where the drain has to come down and I am very limited on space.
Should I clock the turbo more to get more room?
Old 05-04-13, 05:32 AM
  #63
jwin
jwin's Avatar
Correct me if I'm wrong but those two thread location next to where the a/c compressor right below that bolt for the power steering bracket is where the 6 speed Tt dampner bracket would mount to?
Old 05-07-13, 09:48 PM
  #64
jwin
jwin's Avatar
Interior carpet back in.
Did my last round of parts ordering I hope for the engine. Getting a new 6 speed driver side axle, 6 speed dampner, new gates power belt and plastic intake gasket. I should be set until I do my exhaust. I'm almost done well not really but I'm getting close to putting the engine in.
Old 05-08-13, 07:52 AM
  #65
8052JZ
8052JZ's Avatar
You are correct sir!
Old 05-08-13, 01:47 PM
  #66
jwin
jwin's Avatar
Waiting for parts then I shouldn't have an excuse after this last round of parts. Order axle, 6 speed dampner and new timing belt.
Old 05-08-13, 02:00 PM
  #67
ashtray
ashtray's Avatar
What did you decide with the turbo drain line? Is this Borg Warner too big or is it the manifold causing the cramped space issue?
Old 05-08-13, 02:10 PM
  #68
jwin
jwin's Avatar
Borg Warner isn't too big the manifold just sucks for clear shot to the oil drain. I got a metal drain line that I'm going to try as soon as it gets here. The only fitting that I can fit now is a 90 coming off the oil drain.
Old 05-08-13, 02:11 PM
  #69
ashtray
ashtray's Avatar
youre running the xs power mani? ebay?
Old 05-08-13, 02:13 PM
  #70
jwin
jwin's Avatar
Yea with a modified #1 runner.
Old 05-08-13, 02:20 PM
  #71
ashtray
ashtray's Avatar
Okay. Thanks. BTW, got my Tial wastegate
Old 05-08-13, 02:32 PM
  #72
lilSCsteve
lilSCsteve's Avatar
Updates looking good bro, can't wait to see the end.
Old 05-11-13, 10:30 AM
  #73
lookEVO
lookEVO's Avatar
I have the same mani, and run a 45 off the drain. It works pretty good.
Old 05-13-13, 08:15 AM
  #74
Ali SC3
Ali SC3's Avatar
^^ yup, a slight clocking of the turbo and a 45 degree right off the turbo cleared for me with that manifold.
everything is looking great keep it coming.
Old 05-13-13, 05:53 PM
  #75
JesLet
JesLet's Avatar
I like the idea when you use the aluminum tape to paint the block
Just wondering why you chose 38mm TiAl instead of 44mm MV-R?
Did you do the cleaning of the head?
Quick Reply: My 97 sc300 NA-T 6 speed AEM with LQ9 coils build
