My 97 sc300 NA-T 6 speed AEM with LQ9 coils build
#93
Hey Man, question which write up are you using for the cop conversion for your ge? I want to use the factory distributor base as the sensor required for the spark but Im not sure which route I should go, any advice?
#96
I sent my oem clutch disc and pressure plate and told southbend how much hp/Tq I wanted to run and we decided on a 6 pick feramic disc with an upgraded pressure plate. Im pretty impressed. Clutch is installed and I am about to drop the motor in after I finish shrinking the wiring harness.
#99
![](http://i192.photobucket.com/albums/z81/jwinproductions/32D17754-93A2-4BF0-94DE-756EFD7BA422-3073-0000016E28958E90_zpsc0316f16.jpg)
![](http://i192.photobucket.com/albums/z81/jwinproductions/46297D0D-269F-400A-920A-CEB5C2C63909-3073-0000016E3B8C4DFA_zps3dac0dd4.jpg)
Everything is ready to drop in beside my harness which I took apart to make it smaller and to put braided nylon wire loom instead of the plastic. I've been thinking about parting ways with my car. My wife wants me to finish it and enjoy it for a bit then part ways. I know that I won't ever get the money back but will lose even more with it together. Parting out is always better than trying to sell it as a whole. I really don't have the time to put it together with family being more important to me than a car. It is still a very hard decision as I know my shell is limited to buyers with a 6 speed tunnel in it already. I will keep you guys updated on my decision.
#100
The 95-97 SC300 5spds all came with that hump-style tunnel which is exactly the same as the 6spd tunnel because those model year SCs had a tripod shifter on the W58s. Just an FYI.
#102
My wife wants me to keep it, but my job has me in the heat already and the last Thing I wanna do is be back in the heat to work on the car on the weekend. I don't have anything else to upgrade if I part this car out. Last time I parted out my r154 so i could purchase the v160 setup. I need to get some motivation again. STUPID Houston HEAT
#104
I have all of the parts just gotta drop the motor in. Remove the wires I don't need off of the engine wiring harness and put braided nylon on it. Install my new fuel lines and mount my battery box in the trunk. Need to fit my downpipe and intercooler piping then break in my clutch and off to the tuner I go.
How is your adventure going?
#105
