My 97 sc300 NA-T 6 speed AEM with LQ9 coils build
#124
Igniter isn't on the engine harness. I was trying to keep it clean looking. I see a black plug with two big pin in the middle and 6 pin on each side. I'm thinking of using that power wire. It's a plug on the engine harness but connect to something in the kick panel.
#126
Harness is complete.I used pin 78b for the Ecu ground and I will be using the igniter 12v power. I used 51-57 for the 6 coil like you would a 2jzgte. I had a spare Ecu connector and added the extra pins.
![](http://i192.photobucket.com/albums/z81/jwinproductions/F4A9FE87-93C1-4487-A245-AC48EE3578C0-8434-000004008DA96C7B_zps4ef032c4.jpg)
Close up
![](http://i192.photobucket.com/albums/z81/jwinproductions/AA6B0674-E45D-43E8-AC6E-5C1B8F7B20C5-8434-000004008ABF7E0F_zpsfa84e510.jpg)
Hopefully this weekend I will drop the engine in and off to the shop it will go to get the intercooler piping welded and downpipe fitted. I might fit the downpipe myself depending on how hot it is in Houston.
Close up
#130
Yes I did use both the check valve and grommet. You need to have it sideways to clear the coolant tubes from the intake manifold. Mine is really close cause I didn't take that into account instead I wanted a flatter surface. The reason why you use the gte iacv is because of the check valve for boost.
#131
I'm useing a 7m gte iacv but I have a 2j check valve and grommet. But I noticed the bottom of my iacv is the same size as the gommet is it just suppose to squish between or actually seal around the bottom
#132
Looks great, I always chop off those coolant tubes, they are press fit into the iacv, so if you can crush them with a large pair of pressure pliers you can twist and then work them out of the housing also. cutting is easier though.
2jzpowa, the 7mgte idle valve bolts on the same way as the 2jzgte one does and has the same check valve, but the check valve actually sits in a lip on the manifold side's flange, and when you bolt the iacv down it presses up against it if I remember right, so squish seal i guess.
