My SC300 2JZGTE swap - Slow Build!
#78
LOL Quick your so right about that. I had every chance and i failed on that one big time. I will tidy it up tho for sure. Will do it for the overhaul (single turbo, R154, diff, standalone)etc..
Latest:
I need an igniter, supra tt fan (hits water neck) no surprise at all and boost solenoid! Also have to address power steering.
fun times
Latest:
fun times
#80
Question? Can i just get the blade and use my oem sc300 clutch fan assembly? How can i address the broken JDM boost solenoid? Simple as getting a Boost controller? Just kicking around ideas
Thanks in advance all
Highway
Highway
#82
Ignitor - waiting on my guys @ the shop to see if they can get from the local Toyota dealer and price compare to what i've seen. Found the ignitor for $200 online so if they can get from the dealer for a similar price then they'll get it for me if not then i'll order and have it sent 2-3 day. For the boost i'm thinking will convert to true tt and connect a boost controller to the first wastegate. Will also order fan blade today. That should be it hopefully
#87
the tweak harness relocated the igniter inside the cabin rt?i have two boost controllers for sale if you go that route if your going standalone then you don't need em just a solenoid... looking good bro ....get that baby started
#88
Not sure about the relocation... But i got the ignitor with bracket from the place i got the motor from! yay Will figure out the boost scenario after we start her for sure.
#89
Hello gents, Power steering setup question. Is the easiest path just to use a Supra TT reso with my sc300 pump for this swap? I'm providing everything for my mechanic so to make as easy as possible. Been hitting little snags here and there as expected.
Thanks in advance,
Highway
Thanks in advance,
Highway
