Build Threads Details on Club Lexus SC owner vehicles
sc400 w58 2jzgte swap in progress
Old 09-18-13 | 10:42 AM
  #46
Ali SC3's Avatar
Ali SC3
CL Folding 100000
he is talking about the housing area on top where the shifter bolts too. it has a different design than the w58, toyota keeps changing the shifters a little bit. looks like a w55.
And AZ turbo I understand the W series can last a while around 300-350hp, right now my w58 is probably seeing more than that but I drive it very carefully. If it didn't come stock on my car it would be the last transmission I would spend any money on, cause once you put a single turbo on and finish everything else you don't want to be limited to 10-15 psi, that is fun compared to stock sure, but for me feels just normal now If I had an r154 I would have turned up the boost, gotten an lsd and have about twice as much fun with the car.
Old 10-03-13 | 09:26 PM
  #47
Cooldaddy's Avatar
Cooldaddy
How much you think that fun would cost you in tickets lol
Old 10-03-13 | 09:30 PM
  #48
Cooldaddy's Avatar
Cooldaddy
Originally Posted by gambino19
waiting on so more stuff hear is wats in......
cam gears
engine mounts
defi gauges
arp studs
wastegate
oil filter relocator/cooler
Just wanted to say seems you are putting some really nice parts on your engine
Old 10-04-13 | 10:18 PM
  #49
gambino19's Avatar
gambino19
This is me eating humble pie Ali n az was right I check the plate it's a 55
Yea cool. I'm trying to do it rt keeping my eye out for deals as they come.
Update car finally in the shop ready to paint going to freshing up the motor tomorrow. Put the r154 together purchase some well needed parts from Jorge off cl classifieds. Looking like a month or so from start up can't wait!
Old 10-19-13 | 02:36 AM
  #50
gambino19's Avatar
gambino19
My car at the shop. Status pull motor sold it dropped exhaust and driveshaft. Pressure washed the engine bay stripped everything down to paint it. Started freshing up the motor change cam seals crank seals put in the arp studs. Had issues with water pump I have to order a complete on cause the jam doesn't bolt up with the USDm front. Mocked turbo mani have to make adjustments to make it work dremel out the holes so it can bolt up properly. Tapped the oil pan for the return. Place the rear sump on and siliconed everything tight. Removed cam gears. Installed adjustable ones painted the engine block after hitting it with brake cleaner. Sprayed the intake mani with wrinkle paint. sc400 w58 2jzgte swap in progress-image-3215864771.jpg
Attached Thumbnails sc400 w58 2jzgte swap in progress-image-2004351772.jpg   sc400 w58 2jzgte swap in progress-image-3150793736.jpg   sc400 w58 2jzgte swap in progress-image-3192742978.jpg   sc400 w58 2jzgte swap in progress-image-1437606525.jpg   sc400 w58 2jzgte swap in progress-image-189245710.jpg
sc400 w58 2jzgte swap in progress-image-33046105.jpg   sc400 w58 2jzgte swap in progress-image-31439718.jpg   sc400 w58 2jzgte swap in progress-image-2210784765.jpg   sc400 w58 2jzgte swap in progress-image-2760935655.jpg   sc400 w58 2jzgte swap in progress-image-3423746851.jpg
sc400 w58 2jzgte swap in progress-image-206974540.jpg   sc400 w58 2jzgte swap in progress-image-1123490421.jpg   sc400 w58 2jzgte swap in progress-image-4098047980.jpg   sc400 w58 2jzgte swap in progress-image-3737552960.jpg   sc400 w58 2jzgte swap in progress-image-289119433.jpg
sc400 w58 2jzgte swap in progress-image-2219705150.jpg   sc400 w58 2jzgte swap in progress-image-1416770479.jpg   sc400 w58 2jzgte swap in progress-image-1981989172.jpg   sc400 w58 2jzgte swap in progress-image-2789756554.jpg   sc400 w58 2jzgte swap in progress-image-363731632.jpg
sc400 w58 2jzgte swap in progress-image-1976789510.jpg   sc400 w58 2jzgte swap in progress-image-1191291176.jpg   sc400 w58 2jzgte swap in progress-image-2277123369.jpg   sc400 w58 2jzgte swap in progress-image-2033559387.jpg   sc400 w58 2jzgte swap in progress-image-1355334984.jpg
sc400 w58 2jzgte swap in progress-image-2183998669.jpg   sc400 w58 2jzgte swap in progress-image-666679776.jpg   sc400 w58 2jzgte swap in progress-image-3308725811.jpg   sc400 w58 2jzgte swap in progress-image-1654909008.jpg   sc400 w58 2jzgte swap in progress-image-8868965.jpg
sc400 w58 2jzgte swap in progress-image-4246992334.jpg   sc400 w58 2jzgte swap in progress-image-1138959276.jpg   sc400 w58 2jzgte swap in progress-image-2878274114.jpg
Old 10-19-13 | 02:50 AM
  #51
gambino19's Avatar
gambino19
Now waiting on parts from driftmotion. Gotta get an fittings and feeds make breather for valve covers.
Old 10-19-13 | 03:32 AM
  #52
Kris9884's Avatar
Kris9884
Coming along nicely! I must have missed it but what are you doing with the cams and head apart?
Old 10-21-13 | 07:08 AM
  #53
gambino19's Avatar
gambino19
Changing camshaft seals and putting in the arp studs into the block and apply torque
Old 10-21-13 | 02:01 PM
  #54
Ali SC3's Avatar
Ali SC3
CL Folding 100000
engine bay looks nice and clean. coming along nicely. what motor mount brackets are those? they don't look like SC mount brackets. you will need to change them if they are from an aristo or Gs.
Old 10-21-13 | 10:22 PM
  #55
gambino19's Avatar
gambino19
I was wondering about that I need the sc300 brackets right? ....the mounts are for sc300....I didn't change the brackets they came with the motor
Old 10-22-13 | 08:26 PM
  #56
Ali SC3's Avatar
Ali SC3
CL Folding 100000
Yeah you need sc brackets. You probably have aristo ones on right now if it was front sump.
Old 10-26-13 | 12:36 AM
  #57
gambino19's Avatar
gambino19
What about the cross member do I have change that as well? I have it just need to know
Old 10-29-13 | 11:26 PM
  #58
gambino19's Avatar
gambino19
Does anyone ever had a r154 that wouldn't go into gear when it was outside of the car with no fluids need help troubleshooting
Old 08-10-14 | 01:06 PM
  #59
sc300bd's Avatar
sc300bd
I need the w58 shifter extension can any one tell me where i can find it
tjfrom215
Performance & Maintenance
36
12-22-20 12:33 AM
YotaSC400
09-01-16 03:48 PM
DrBrown54
SC- 1st Gen (1992-2000)
12-10-14 11:07 AM
Ke0
02-05-09 06:30 PM
Grey Ghost
01-20-07 11:21 AM
