is300 SLAMMED/FITMENT/DUAL-EXHAUST
#66
heres a few pics from a local meet
![](http://imagizer.imageshack.us/v2/xq90/208/zzxv.jpg)
![](http://imagizer.imageshack.us/v2/xq90/812/4gts.jpg)
![](http://imagizer.imageshack.us/v2/xq90/812/iimw.jpg)
so i found out my radiator was leaking and my reservoir tank was cracked and since that happened it went on my serpentine belt so i went ahead purchased
new parts
radiator, oem reservoir tank shroud,oem hoses, dayco belt
![](http://s11.postimg.org/3q1krp783/CAM00276.jpg)
i also thought it was time to upgrade my exhaust tips. they have better days
AND THIS IS WATS LEFT OF MY MUFF TIP :confused
these are tanabe hyper medallion
![](http://s13.postimg.org/58fu1ekt3/CAM00234.jpg)
image hosting
as stated im looking to peruse vip stance. i was inspired by this car to upgrade my tips
![](http://s30.postimg.org/x9e74la75/VIP_Style_Lexus_Junction_Produce_09.jpg)
image upload software
so i went ahead and bought
these
4in outer 12in length with a 2.25 ins
![](http://s28.postimg.org/7krygy2a5/CAM00274.jpg)
free screenshot
![](http://s8.postimg.org/cqbjtlwqt/CAM00275.jpg)
imgurl
so i rear ended someone . and have been driving around with broken tabs and a messed up bumper. luckily it was little damage
![](http://s30.postimg.org/nst0ze54h/CAM00371.jpg)
![](http://s3.postimg.org/arxt76143/CAM00372.jpg)
using that as an excuse to fix the front end i went ahead and bought some chrome housing headlights and 5k hid bulbs
![](http://s4.postimg.org/ppe8c5ni5/CAM00433.jpg)
after that did a little baking and opened up my sportcross fogs light and sanded down the
the yellow .originally i liked yellow but going a different direction
![](http://s30.postimg.org/owviubjap/CAM00452.jpg)
comparison
![](http://s2.postimg.org/oybo9btfd/CAM00454.jpg)
complete but going to get them wet sanded as well and also ordered some 5k high power led bulbs to match
![](http://s30.postimg.org/up5acbott/CAM00455.jpg)
![](http://s22.postimg.org/xwhm8ovip/CAM00478.jpg)
so about 3 day later i dropped my car off and this is the progress. getting the hood repainted and the fenders pulled by 2in. also getting the front bumper fixed and shaving the front side markers
![](http://s30.postimg.org/89muu5z01/CAM00457.jpg)
![](http://s27.postimg.org/v3s7mjv0j/CAM00458.jpg)
![](http://s13.postimg.org/lbklcj7w7/CAM00456.jpg)
will post more pics hopefully ready by tomorrow
new parts
image hosting
these
free screenshot
imgurl
comparison
#68
#69
This is my new account just fyi (dtcsurfer). I bought two LED strips, a switch, and wiring. Their should be a ground, supply volt, and on ACC options on the switch. Put the switch wherever you want. What I did was i drilled a hole in one of those clip-in things next to the traction control switch (You can put the wiring through the inside of the middle console area). Then put your LED strips under both the foot wells and have the negative wires from the strips connect to the ground option of the switch, and the positive wires from the strips to the on ACC option on the switch. Then use the extra wiring you got and connect a piece from the ground option to any metal in the driver side foot well area (tape or screw). Now connect a piece from the supply volt option all the way to the battery of the car. There is a small hole you have to cut open on the driver side to get wiring into the engine bay, and put the wiring on the positive part of the battery (red). Tuck all the wiring in and your good to go. I installed mine a while ago so I might of mixed up some things but you can check other DIY forums to make sure you do it right.
#70
so the car has been on the road for about 2 weeks now but just didnt post pics till i had to time adjust the coils . i also came across a deal for some euroline dhs . and picked up a oem chrome trunk bar .and took some quick pics out side
![](http://s17.postimg.org/t4a8kx26n/CAM00528.jpg)
![](http://s15.postimg.org/bi9oebl2z/CAM00529.jpg)
image hosting 12mb
18x8.5 +45 18x9.5 +40
![](http://s24.postimg.org/z7iashy9h/IMG_20140612_011249.jpg)
post images
<embed width="540" height="520" type="application/x-shockwave-flash" src="http://v8.tinypic.com/player.swf?file=iej81c&s=8"><br><font size="1"><a href="http://tinypic.com/player.php?v=iej81c&s=8">Original Video</a> - More videos at <a href="http://tinypic.com">TinyPic</a></font>
![](http://s17.postimg.org/k7uv38m6n/CAM00543.jpg)
images upload
![](http://s28.postimg.org/vdknvphgt/CAM00546.jpg)
image sharing
image hosting 12mb
post images
images upload
image sharing
#71
![](http://s27.postimg.org/qhex76phf/CAM00689.jpg)
![](http://s29.postimg.org/bq88ww2av/CAM00690.jpg)
photo upload
25mm and 38mm spacers
![](http://s2.postimg.org/a6on7whc9/20140717_135248.jpg)
havent installed any of the parts yet just thought id share these pics
![](http://s11.postimg.org/mzgr3kctv/20140715_170357.jpg)
![](http://s24.postimg.org/fv9i86oz9/20140715_170710.jpg)
screen capture windows
#74
I just got an 02 Is300 , it has been my dream car for the longest and I've always liked dual exhaust but never seen any with it so I thought it wasn't possible but now thanks to you I know it is ! Thanks a lot for this info bro !
O. L. T.
IS - 1st Gen (2001-2005)
03-04-05 06:22 PM
