chrispy's Build Thread
Small update. Since I got my coilovers my front upper control arms keep banging the top so I cut some holes.
I used a 2 1/2 inch hole saw. A carbide one is more expensive but it will cut much smoother and last longer.
![chrispy's Build Thread-ndie5vl.jpg](https://www.clublexus.com/forums/attachments/build-threads/499560d1683165171t-chrispy-s-build-thread-ndie5vl.jpg)
Look to see where it's banging and drill a pilot hole to the top.
![chrispy's Build Thread-0zxxge4.jpg](https://www.clublexus.com/forums/attachments/build-threads/499561d1683165171t-chrispy-s-build-thread-0zxxge4.jpg)
Then use that hole you made to guide the holesaw down.
![chrispy's Build Thread-94rvl0d.jpg](https://www.clublexus.com/forums/attachments/build-threads/499562d1683165171t-chrispy-s-build-thread-94rvl0d.jpg)
![chrispy's Build Thread-sn2vnx6.jpg](https://www.clublexus.com/forums/attachments/build-threads/499563d1683165171t-chrispy-s-build-thread-sn2vnx6.jpg)
Use some sandpaper and smooth out the edges. I made a slight mistake so I had to touch up a few spots.
![chrispy's Build Thread-8lihcl4.jpg](https://www.clublexus.com/forums/attachments/build-threads/499564d1683165171t-chrispy-s-build-thread-8lihcl4.jpg)
I covered the top with some tape and sprayed it with some paint so it won't rust. Then I used touchup paint for the top. I'm looking for a rubber gasket that fits the hole to keep the dust out. It's nice because the LS has engine covers to hide the holes. I have no more UCA banging problems.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I should have more updates coming soon.
Update! Sold my Junction Produce Scaras to Mattbeezy. I decided I wanted to try out some 20's.
![chrispy's Build Thread-oaeklg2.jpg](https://www.clublexus.com/forums/attachments/build-threads/499483d1683165132t-chrispy-s-build-thread-oaeklg2.jpg)
Picked up some suspension pieces.
Nagisa Auto camber multi adapter. Lowers the car 30mm, adds 2.5 degrees of negative camber, moves the caster forward 10mm, and gives me more suspension travel in the front. These things are amazing! They correct so many problems with the front suspension.
![chrispy's Build Thread-yechw35.jpg](https://www.clublexus.com/forums/attachments/build-threads/499484d1683165132t-chrispy-s-build-thread-yechw35.jpg)
Megan camber arms, traction arms, and toe arms. Toe arms not pictured. Looks like they updated the paint job on these things. They are sparkly blue now! In order to match the front camber, I needed to add in the camber arms, but that pushes the wheels too far forward. That's where the traction arms come in to center the wheel inside the wheel wells. But that throws off the toe drastically so I got the toe arms just for ease of alignment.
![chrispy's Build Thread-gfopek7.jpg](https://www.clublexus.com/forums/attachments/build-threads/499485d1683165132t-chrispy-s-build-thread-gfopek7.jpg)
![chrispy's Build Thread-w0vzpai.jpg](https://www.clublexus.com/forums/attachments/build-threads/499486d1683165132t-chrispy-s-build-thread-w0vzpai.jpg)
YouZealand SS kit pro. Lowers the car 30mm all around and fixes the roll center. The car tracks much better with the corrected suspension geometry. Since I have the Nagisa block up front, I'm only using the rear for this setup.
![chrispy's Build Thread-yyye7z8.jpg](https://www.clublexus.com/forums/attachments/build-threads/499487d1683165132t-chrispy-s-build-thread-yyye7z8.jpg)
And a teaser for the upcoming new wheels.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
![chrispy's Build Thread-bnk7cey.jpg](https://www.clublexus.com/forums/attachments/build-threads/499488d1683165132t-chrispy-s-build-thread-bnk7cey.jpg)
![chrispy's Build Thread-gfopek7.jpg](https://www.clublexus.com/forums/attachments/build-threads/499481d1683165132t-chrispy-s-build-thread-gfopek7.jpg)
![chrispy's Build Thread-w0vzpai.jpg](https://www.clublexus.com/forums/attachments/build-threads/499482d1683165132t-chrispy-s-build-thread-w0vzpai.jpg)
Have you seen there pink set up now!?! lol
