CatManD3W SC300 Ongoing Build...
#481
#482
I just finished up installing the passenger seat but I choose to go with wedge engineering bracket and slider....I must say that the seat is solid and does not move....
The wedge engineering bracket and slider sits lower.....looks like I will be ordering the wedge engineering bracket and slider as well for drivers side so they match..
Sparco Slider and bracket will up for sale....PM me if you want it
#487
The front seats look good in there man. I'd like to see what you come up with for the rear seat delete. I had thought about doing a rear delete in my IS300 but I think with it being a 4 door it would seem a little weird.
#490
Thanks....I have finally ordered the supra radiator shroud and also will be installing a BCC from MVP motorsports...see how much room i have left on the 440s till i lean out....at 14psi ,I am reading low 10.2-10.8..on AFR..still pretty rich...see if it can go up to 16psi....
I really do not want wire in resistor pack for 550cc Supra low impedance injectors..... I might just buy the high impedance sard ones that are drop in for Aristo
#491
Finally ordered and installed Supra radiator shroud...I had to make 2 brackets for top portion of shroud since I am using SC radiator....You can see the one in the pic it will be painted black
![Name: 20150320_223817_zps0gmtpluc.jpg
Size: 174.6 KB](https://www.clublexus.com/forums/attachments/build-threads/423394d1501292664-catmand3w-sc300-ongoing-build-20150320_223817_zps0gmtpluc.jpg)
Also installed ARP wheel studs on both front hubs....
![Name: 20150320_224054_zps3bg4wiuv.jpg
Size: 194.9 KB](https://www.clublexus.com/forums/attachments/build-threads/423395d1501292664-catmand3w-sc300-ongoing-build-20150320_224054_zps3bg4wiuv.jpg)
Next items on the list are to install MVPMotorsports BCC, order CROW 5 pt harnesses and begin work on rear seat delete.....
