Build Threads Details on Club Lexus SC owner vehicles
CatManD3W SC300 Ongoing Build...
Old 03-31-15, 07:45 AM
  #496
gerrb
Super Moderator
gerrb's Avatar
That whole black color all around the lower part of the car made the car stand out and looked good !
Old 03-31-15, 11:56 AM
  #497
CatManD3W
CatManD3W's Avatar
Thanks Gerry it is nice out today and I am in the process of doing the ebrake handle and leather boot cover....as well as putting together my passenger door panel....I have decided to SEM the center console trim as well
Will update later with pics....
Old 03-31-15, 06:48 PM
  #498
CatManD3W
CatManD3W's Avatar
Well guys my interior is finally all back together......been driving around for about a yr without a passenger door panel....
Broken piece...
I was able to get a good deal from another member on CL for a door panel....I only needed the lower portion....
SEM going on...to get a perfect finish you need to use the prep cleaners.....
Ended up doing a few other pieces to complete the black out look...
Trusty old shovel....It worked great for the ebrake boot....
Passenger door panel all back together...
Everything back in place....I really love this look...forgot to put the key ring plastic piece back in...but I also gave it a fresh coat since it got scratched up from key
Here is what it looked like when I first bought it....For reference on the dramatic change
Bye bye rear seats.....I spent a good hr back there with degreaser getting it all cleaned up....
Old 03-31-15, 10:19 PM
  #499
oldManTan
oldManTan's Avatar
Epic man, this is one of my favorite threads of all time, true inspiration.
Old 04-01-15, 05:42 AM
  #500
CatManD3W
CatManD3W's Avatar
Thanks man....
Old 04-01-15, 06:15 AM
  #501
ems
ems's Avatar
how long does the sem take to set and does it smell after being in the car?
Old 04-01-15, 07:00 AM
  #502
CatManD3W
CatManD3W's Avatar
Its just like spray paint.....but make sure you do it in a well ventilated area......its smells horrific lol...
Not that bad....I usually try to leave them outside as long as possible before installing them....If you can get them in the sun for a few hrs is your best bet
Also keep in mind I only did the lower trim piece in the pics with SEM....The rest of door panel is wrapped with new vinyl
Old 04-01-15, 12:23 PM
  #503
TweakedIS3
TweakedIS3's Avatar
Man I love seeing your progress. It makes me want to go work on my car even though I don't know where to start lol.. My interior is all tan and seeing the transformation on your car is giving me the itch to change some things up on mine.
Old 04-01-15, 08:10 PM
  #504
CatManD3W
CatManD3W's Avatar
Good deal....it has taken awhile for me to piece it all together
Old 04-07-15, 05:36 PM
  #505
CatManD3W
CatManD3W's Avatar
Case of yzzd3 oil filers...I use these both on SC and on my Tacoma...
Old 04-10-15, 05:07 AM
  #506
SC400TT
SC400TT's Avatar
Broken piece...
Nice job with the SEM. What color black did you use? The color code?
Thanks
Old 04-10-15, 06:13 AM
  #507
CatManD3W
CatManD3W's Avatar
Landau Black
Old 04-18-15, 01:23 PM
  #508
CatManD3W
CatManD3W's Avatar
Next level of build...taking it up a notch...
Just got back home after driving a total of 8 hrs to Freed Engineering and meeting Omar (99SC42)....
Brought all this back with me...This setup should be pretty much bullet proof....Thanks again Omar....
I couldnt pass this up....Complete package deal to do the swap
Specs on the fully built chaser/soarer tripod r154...was done by Freed engineering (Ben Freed informed me that this has every possible upgrade done to it)
1,2,3,4 and Reverse Gear are all brand new .
Marlin Crawler Rebuild kit with HD bearings
1st, 2nd, 3rd gear
1/2 hub
1/2 slider
New Marlin Crawler thrust washer
Already had Marlin Crawler bearing retainer and fork
Custom built southbend clutch and pressure plate......rated to handle 700 ft lbs of torque
Old 04-19-15, 12:22 AM
  #509
oldManTan
oldManTan's Avatar
Epic!!! Didn't think this could get better but it just did!
Old 04-19-15, 10:15 AM
  #510
CatManD3W
CatManD3W's Avatar
Thanks man....I cant wait to get the new transmission in and finally be able to push the car a little bit harder....
Now that I have eliminated the weak link in my setup I can start to turn up the boost.....
Im not going for any crazy high hp numbers....I would be satisfied if I could get close to 500hp
Quick Reply: CatManD3W SC300 Ongoing Build...
