CatManD3W SC300 Ongoing Build...
#871
^^ I also did mine with the engine in. I used the bendible copper looking line from Autozone. Turned out OK but I too will redo it again someday because it's hard to do a super clean job when you're trying to work around the motor and everything in the engine bay. Probably next time the engine is out I'll redo it.
#883
Starting to collect parts for the Tremec t56 swap. Also prepping the 5spd SC300 diff and getting ready to fit TRD LSD into it.
Next purchase will be the transmission itself. But a lot of work to do before hand, plan on dropping out the subframe and replacing all bushing with poly ones.
2jz to T56 Bellhousing
Custom Clutchmasters clutch setup from Grannas Racing...believe im the first one to order the single disk option. its a full race disk
#885
The Quicktime Bellhousing is made out of Steel.
The cast aluminum bellhousing is made by Castlemaine Rod Shop (CRS) which is based out of Australia. But Grannas buys them in bulk and sells them.
Castlemaine Rod Shop:
http://www.rodshop.com.au/bellhousings/toyota-1jz-2jz/gm-tremec-t56.html?make=162&cat=579&part_type=131
