My SC300 build log!
Mike on your heater controls. How did you change the bulbs? I saw I have one out in the center of mine and I have to replace it. Just wondering if its a hard thing to do, or if I have to do some soldering
took a while for me to get back in the game, I was moving cross country
here's more stuff I got
16621-46010 ABSORBER LOWER BRACKET $36.91
(Not Taxable) 1 $36.91
16622-46010 ABSORBER UPPER BRACKET $17.61
(Not Taxable) 1 $17.61
16620-46070 TENSIONER $178.92
(Not Taxable) 1 $178.92
16602-46010 ABSORBER $57.02
(Not Taxable) 1 $57.02
91511-G0845 BOLT, FLANGE $0.84
(Not Taxable) 2 $1.68
90901-16001 BOLT, STUD $2.06
(Not Taxable) 1 $2.06
90179-08171 NUT $0.80
(Not Taxable) 2 $1.60
90080-17242 A/C Compressor Nut $1.18
(Not Taxable) 2 $2.36
82998-12440 TERMINAL, REPAIR W/W $4.57
(Not Taxable) 2 $9.14
12371-46110 REAR MOUNT $58.18
(Not Taxable) 1 $58.18
31470-14060 SLAVE CYLINDER $55.12
(Not Taxable) 1 $55.12
90080-10055 BOLT, WASHER BASED H $0.80
90179-08237 ABS Control Module Nut $0.84
31481-14260 STEEL LINE $21.43
(Not Taxable) 1 $21.43
96816-50335 FLEX HOSE $20.77
(Not Taxable) 1 $20.77
31484-24010 BRACKET, FLEXIBLE HO $5.67
(Not Taxable) 1 $5.67
31482-14060 STEEL LINE $10.01
(Not Taxable) 1 $10.01
90119-06406 BOLT, W/WASHER $0.66
(Not Taxable) 1 $0.66
96991-10080 CLIP $1.05
(Not Taxable) 2 $2.10
90119-06733 BOLT, W/WASHER $0.63
(Not Taxable) 1 $0.63
90363-12002-77 Clutch Pilot Bearing $5.72
(Not Taxable) 1 $5.72
31231-14050 RELEASE BEARING $29.26
(Not Taxable) 1 $29.26
31204-14060 RELEASE FORK $59.27
(Not Taxable) 1 $59.27
90119-08079 BOLT, W/WASHER $0.50
(Not Taxable) 6 $3.00
42340-14140 AXLE ASSY $375.94
(Not Taxable) 1 $375.94
90116-08348 BOLT, STUD $0.76
(Not Taxable) 3 $2.28
did a little testing with plasti dip
![My SC300 build log!-20140228_142923.jpg](https://www.clublexus.com/forums/attachments/build-threads/325896d1461368899t-my-sc300-build-log-20140228_142923.jpg)
![My SC300 build log!-20140228_142939.jpg](https://www.clublexus.com/forums/attachments/build-threads/325897d1461368899t-my-sc300-build-log-20140228_142939.jpg)
![My SC300 build log!-20140228_142941.jpg](https://www.clublexus.com/forums/attachments/build-threads/325898d1461368899t-my-sc300-build-log-20140228_142941.jpg)
