2JZGTE rebuild
11-07-13, 02:27 PM
Quote:
Originally Posted by
JesLet
Where is your build thread... I want to see that NA-t
lol u too! i will try brother.. probably do a before and after pics, literelly.
11-07-13, 02:59 PM
Super Moderator
that dremel tool did good huh
JesLet
We will force him to do a build thread don't worry
or we are not helping him.
PoGikoSc4
Nah.. I want to see pictures of that block and peripherals getting cleaned up.
11-07-13, 03:21 PM
I tried hacksaw but it was too hard haha
11-07-13, 11:33 PM
Flywheel ready to bolt in
ARP says to put assembly lubricant under heads and Loctite 242 ( red ) on threads and torque to 70 ft. lbs
Torqued in sequence ... and done. Pilot bearing installed with larger hole for the AR5 input shaft
11-08-13, 11:46 AM
this is so awesome, can't wait to see the ar5 mated to the 2jz. thanks for sharing your build.
I'm assuming the r154 shifter extension does not fit the ar5.
Do you think it would be possible to cut and weld the ar5 shifter assembly shorter?
11-08-13, 01:45 PM
very clean build, cant wait to see the outcome when it is finished.
11-08-13, 03:35 PM
megomaniac
No does not fit but you can do this: see post #23
http://www.supramania.com/forums/sho...Solution/page3
monkey92
Thanks buddy
11-09-13, 11:52 AM
KahnBB6
JesLet, thinking on it further I do recommend getting a crate service for shipping a long block. I inspected a Merc OM606 diesel long block that a friend in Cali had just bought himself and that thing was going onto a palette (bolted down and strapped). A crate would have sufficed just as well. I believe Fedex was also used to ship that thing from FL to CA.
Transmissions can go in containers because they weigh a lot less.
Hell of a big engine, by the way, that 606. Finns love them the way we love 2JZ's.
Just the engine block without the head and oil pan... Still heavy though.
11-09-13, 11:57 AM
11-09-13, 12:39 PM
Looking really good there. Yeesh... I couldn't get my R154 that spotless and I scrubbed the hell out of it.
11-09-13, 01:34 PM
Me either! I think bead blasting would be the only way to get mine that clean.
11-09-13, 04:06 PM
stockhatch
KahnBB6
Thanks guys. No need to clean it.. nobody looks at your transmission anyway
Worked 8 hours today:
Wiring on
Coilapcks on
Lube for the clutch area
Ready to go in
Decided to not to bolt the transmission for now. Dont' want to add weight to the oil pan.
Decided to tackle the tunnel
Tommorow will be the cleaning of engine bay, new heater hose and Supra thottle cable, effing tired! Snack time!!!!
11-10-13, 10:06 AM
Gunk Engine Brite and power wash did the job
11-11-13, 11:30 AM
Lookin good. You should make a stick for the trans swap. Ill probly have an easer chance finding one here in hawaii than a 154 for a good price. So I will be referencing this.
11-11-13, 02:56 PM
konaboi808
Thanks man.
It was harder than I thought
GM mount into Lexus bracket... still working on it
