Hmmm. Tranny xmember is far from ideal. I would recommend building a new xmember over spacing that one to such an extreme. Engine looks great in there though!
It will take a while... I take too much snack breaks
Originally Posted by soarer13oy
would totally have to agree.
Originally Posted by PoGikoSc4
Yo D, any update on that crossmember? Motor looking nice man ..
Still working on it. I wish I have access to machinery so i can build my own crossmember.
I am going to install the Tial 44 and It came with all springs.
At what PSI ( springs ) do you suggest for 550cc/single turbo/piggyback aiming for maybe 400rwhp? 10-12 PSI?
I plan to run a 10psi spring. I figure after pressure drop across the intercooler, te intake may actually see around 9. Maybe an expert will chime in, but I hear springs are generally good for double their rating when using a boost controller. You may want to go for 10 like you said.
Originally Posted by KahnBB6
This I also did not know. Thanks, stockhatch! Is the same true of solid engine mounts? I have never understood that rationale.
I should clarify that a little bit. If you run dampened engine mounts, and a solid tranny mount, you can crack the tailshaft because the engine movement ends up twisting the tailshaft. If you run solid mounts all around, you should not have that issue theoretically, but the NVH is TERRIBLE with solid mounts in my experience. Even running the encased supra mounts makes the engine noticeably harsher over the lexus rubber, but I still run them since they are bulletproof.
