2JZGTE rebuild
#256
I plan to run a 10psi spring. I figure after pressure drop across the intercooler, te intake may actually see around 9. Maybe an expert will chime in, but I hear springs are generally good for double their rating when using a boost controller. You may want to go for 10 like you said.
I should clarify that a little bit. If you run dampened engine mounts, and a solid tranny mount, you can crack the tailshaft because the engine movement ends up twisting the tailshaft. If you run solid mounts all around, you should not have that issue theoretically, but the NVH is TERRIBLE with solid mounts in my experience. Even running the encased supra mounts makes the engine noticeably harsher over the lexus rubber, but I still run them since they are bulletproof.
This is also why I wanted to attempt running a factory R154 trans mount if at all possible despite the crossmember incompatibility. Thankfully I did figure out a solution that uses the MKIII mount. JesLet, I actually haven't scrutinized your pictures. Is there any similarity to the tail mounting holes between the AR5 and the MKIII R154? I know you've got your solution in the works-- just curious.
#257
Good info, thank you! My plan has been to upgrade to Supra engine mounts when necessary (I've read that Supra TRD mounts are VERY harsh in comparison). The car already has been made somewhat stiffer than factory so I don't think it will make much difference. Bulletproof is good!
Here's what i have for strenghtening the factory crossmember. Don't hate
#258
#265
Jeslet, truly awesome build bro...you're attention to detail, ef'n amazing! Definitely one of my favorite builds to date! And hey, I love my dremel too...that thing is awesome right? lol
steve
steve
#266
Thanks for kind words... Yes that Dremel is awesome. It has beaten to death, overheated, 3rd pair of carbon brush and still running!
