2JZGTE rebuild
#333
Thanks!
I guess the smoking is normal....
http://www.rx7club.com/3rd-generatio...himney-548882/
http://www.buellxb.com/Buell-XB-Foru...ust-Wrap-Smoke
#334
1 Post
congrats on the start up brother!! looks and sounded good. i think the smoke is normal coming from the heat wrap(pls someone correct me if im wrong). it should go away after a while.. did you buy the silicon coat for your heat wrap? im not sure if it will help w/ the heat but if you wanna change the color of wrap might wanna check em out. Congrats again..
#335
#336
1 Post
DEI silicone spray. I think you spray it once you wrap your manifold. Im not sure whats the purpose but i just mentioned it if you wanted to change the color of your wrap.
#339
That is normal for the heat wrap to smoke. Usually when you wrap something your suppose to soak the wrap in water than wrap it super tight, than spray it down with silicone spray made for heat wrap after it drys out. I just use regular exhaust paint which works as well. After the warp is "broken in". It will shrink tighter onto the dp and stop smoking after a couple miles of driving.
#340
Thank you, thanks again about the 550 resistor wiring.
![](http://i1049.photobucket.com/albums/s384/Dennis_Lansang/20131212_122606.jpg)
