2JZGTE rebuild
#421
#422
Here's the link for cluster resistor mod and GM 2-wire speed sensor
https://www.clublexus.com/forums/per...or-sender.html
#423
Hmmm, did you visually check to see if the valve is opening now? If it's not, bypass the vsv and put the vacuum source right on the actuator to make sure the signal and diaphragm are good. If it opens then, you will need to verify the vsv wiring.
#425
http://www.dakotadigital.com/pdf/sgi-5.pdf
#426
I got the tach and speedo fixed now I am doing the AIRBAG light. I am trying to diagnose what caused the light to turn on before clearing it.
According to this link, I should clear the airbag light only if i have a code 22.
http://lextech.org/forums/index.php?topic=9.0
When I wire TC and E1 as per instruction, my CRUISE and ABS are blinking intermittently. AIBAG light is still on and not blinking, so this means it is not code 22.
Should I clear it anyway and maybe buy another spare of airbag haha
#431
Love how close the car has come to completion, JesLet! And the AR-5 is shifting and cruising just fine now? You've put an excellent example here for the community to see how it's done!
#433
#435
hhhmmm been busy with that IS300 huh ? You can now send me your 2jzgte harness so I can look at it. You said you have an odb1 harness right ? And you have an odb2 car right ?
Don't forget to send that bottle of Patron too. I am out of stock...lmaol. J/K
Damn, before I forget . How is my 2jzge short block ? I hope it isn't rusty yet .
