Build Threads Details on Club Lexus SC owner vehicles
2JZGTE rebuild
Old 08-23-13, 04:13 PM
  #76
gerrb
Super Moderator
gerrb's Avatar
Dennis - you would have a clean looking engine bay I imagine with all the polishing and cleaning up of those parts.
Old 08-23-13, 04:39 PM
  #77
JesLet
JesLet's Avatar
You know it is not as bad *** as yours.
Old 08-23-13, 05:53 PM
  #78
stockhatch
stockhatch's Avatar
Originally Posted by JesLet
stockhatch, did yours go bad?
My engine? It had cold start rattle and smoked in certain situations, so I went through the bottom end. It actually ran great and never gave me any serious trouble. Gotta love a JZ
Old 08-23-13, 05:55 PM
  #79
JesLet
JesLet's Avatar
Were you having issues about that wrist pin thing?
Old 08-23-13, 07:21 PM
  #80
stockhatch
stockhatch's Avatar
Tough to say whether the cold start rattle was wrist pin or big end bearings, so I can't tell you with any certainty. I just replaced mine because they were out of spec according to the book.
Old 08-23-13, 08:24 PM
  #81
Reyke
Reyke's Avatar
First, did you check for wrist pin movement before reusing your pistons? When I rebuilt my 2JZ, most of the pistons were worn beyond the service limit. The way to tell is to try to move the wrist pin within the piston at room temp. If it moves within the piston, the piston needs to be replaced. The wrist pins should be an interference fit at room temp and require piston heating to install.
Wait I could have sworn the wrist pins in these engines were floating, with bushed small end bore and c clips to retain them in the bore
If I'm wrong I guess they build 2JZ's differently between the years.
Old 08-24-13, 06:23 AM
  #82
stockhatch
stockhatch's Avatar
Out of the only TSRM I have seen:
If there are other TSRMs for the 2jz, I have not found them.
Old 08-24-13, 01:56 PM
  #83
Reyke
Reyke's Avatar
What's interesting is the whole, " if there is any movement from the pin then it is to be replaced"
I personally prefer exact measurements, some people can feel a thousandths worth of play while others can't, and heating the pistons to 176 F is the same as holding a slightly hot cup of coffee, and if the tolerances are that tight it would be nice if Toyota would give exact numbers, becuase the piston gets hotter than that during the combustion process. I did find a manual that went into a bit more detail. Here's the link:
http://www.97supraturbo.com/Tech.html
The info for the pistons is in the " Engine Repair" PDF and is on 50, 53, and 54
Old 08-24-13, 08:29 PM
  #84
JesLet
JesLet's Avatar
I wanted to finish the build this weekend but I ran into couple of issues. First, the shims that I ordered was missing 1 shim. Curt said he sent it overnight and it supposed to be here Saturday. I reinstalled all the shims and replaced the missing one with smaller spec but it was still tight. Everything is in spec except for that one. Gotta love the TSRM for checking out the clearances. And secondly, one of the cheapie cam gears I bought has bigger hole for the camshaft's dowel pin. Made a video below since I am bored.
Bad cam gear:
Good cam gear :
Left cam gear has bigger dowel pin hole
Used shims
And she's waiting.... waiting.... waiting.. hmp!!!
Old 08-24-13, 08:45 PM
  #85
SeoulMan24
SeoulMan24's Avatar
Dunno why, but these builds make me nervous! Keep up the good work!
Old 08-24-13, 08:46 PM
  #86
JesLet
JesLet's Avatar
Picture whoring tonight
Manifold downpipe ready for new flange
Welded
Marmon flange for the BW S366
Old 08-24-13, 08:48 PM
  #87
JesLet
JesLet's Avatar
What do you mean? Seems like you build engines too according to your sig. Am I doing something wrong here?
Old 08-24-13, 09:03 PM
  #88
JesLet
JesLet's Avatar
Okay it is Saturday, need to get off the computer
Old 08-25-13, 04:50 AM
  #89
stockhatch
stockhatch's Avatar
I pulled my pics from the same book. I just didn't include anything not related to the pin fitment. I also hear you on the measurements, but all we have to go on is what Toyota gives us.
Old 08-25-13, 04:51 AM
  #90
stockhatch
stockhatch's Avatar
JesLet, I like the looks of that clutch. What are the specs on it?
Quick Reply: 2JZGTE rebuild
