Build Threads Details on Club Lexus SC owner vehicles
2JZGTE rebuild
Old 08-29-13, 04:20 AM
  #121
gerrb
Super Moderator
gerrb's Avatar
That is the beauty of having an ECU with failsafe features. It will monitor different things for you like coolant temp, oil pressure , fuel pressure, 02 Lean and what not so you worry less about your engine being damaged and have more time enjoying your car. Like , it will shutdown the engine or do whatever is specified on the failsafes .
Mark , your AEM v2 has some of them already .. go use them buddy !
Old 08-29-13, 06:36 AM
  #122
99SC42
99SC42's Avatar
Ok but why use some bs vaccum cap to cap a coolant port? Because you have an ecu that can monitor it?
All those failsafes came from Proefi, Jason did that years ago, and i don't think v2 has all that , i know 100% the Infinity has 98% of the failsafes.
Back to topic
Op take the WP off and have it welded shut if you are going for a clean look, Or you can actually pull the fitting off and use a short 12-14mm bolt to plug it.
1jzpwr is 100% correct that thing will pop on you within a couple hundred miles.
Old 08-29-13, 07:01 AM
  #123
gerrb
Super Moderator
gerrb's Avatar
Back to topic
Looks to me somebody is jumping on the gun , you are barking on the wrong tree . You may want to ask the OP why he used "some bs vacuum cap to cap a coolant port ?" . I didn't do it neither did I suggest it .... neither did we even talk about it .
And no body ever said the v2 has all what proEFI failsafe can provide. Exactly the reason why I was replacing the v2 with a proEFI cause I find its failsafes a lot better.
All I told the OP was were to find the relief hole since he was looking for it , talked about the beauty of an ECU with failsafes and since Mark has a V2 with failsafes , he might as well use them .
Old 08-29-13, 07:21 AM
  #124
99SC42
99SC42's Avatar
I sounded like you told him to use that cap, and he said capped OFF , Thanks Gerry.
And then it sounded more obvious when you started talking about Ecu and Failsafes crap, SO you either talk to the OP or you were OT.
So i'm sorry!
And this Thread is about the OP, not me , not You , not Mark , Wanna talk about ECU start your own thread please.
Old 08-29-13, 07:44 AM
  #125
gerrb
Super Moderator
gerrb's Avatar
Apology accepted !
Just for your info and to make things straight . The reason why I mentioned about the ECU on the OP thread was because he and I converse a lot both on PMs, emails and text messages about his built . He does communicate with me often. I listen to what he tells me and at times give my point of view but never told him emphatically to do this or do that. So for me it was worthwhile to mention it on his thread for him to know since he hasn't finalize his parts gathering. I didn't talk about the ECU just for the sake of talking about ECUs and to add another thread to the so many threads about ECUs ?.... no point . Just as I always mentioned , everyone has his own liking to what ECU he wants to use. And I am not one who will argue about ECUs. Who am I to argue anything about automotives ? It ain't what I went to school for so I don't know much as I always said.
And again even if the OP and I converse a lot , not once we have talked about that coolant port being capped.
Old 08-29-13, 07:53 PM
  #126
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I believe this whole thing was a misunderstanding between the two parties. Jerry, glad you accepted the apology, and Quick thank you for saying it. For future reference, let's stay on topic and help each other on their builds. We all have learned some useful Do's and Dont's along the way with every build. I knew from experience that that style of cap would not work. I ended up using JB weld and a coolant cap to ensure mine didn't ever leak again. Even the cap somehow dry rotted, the JB weld would still hold it. Mine should have been welded shut from the get go, but no one told me, so that was my lesson learned. Cost me being on the side of the wrong running hot. Bummer.
Any more progress on the build this afternoon?
Old 08-30-13, 02:24 AM
  #127
konaboi808
konaboi808's Avatar
Siik *** build brah
Old 08-31-13, 11:12 AM
  #128
JesLet
JesLet's Avatar
Messing with ebay manifold.
Old 08-31-13, 11:29 AM
  #129
gerrb
Super Moderator
gerrb's Avatar
Did you get the thing that you were telling me in the mail yet ? That should help you a lot for sure.
Btw , just my opinion .. using the oem manifold gasket regardless of what manifold you use will be better in the long run. Those gaskets that come with those manifolds will more likely leak after some time. A lot of people use Ebay manifolds , even I have it on the red mamba so don't feel bad about it. It's your money and your car .. do and use what you want . We are just spectators.
And thank you for posting again !
Old 08-31-13, 11:42 AM
  #130
JesLet
JesLet's Avatar
Good to know, I still have my OE gaskets
Old 08-31-13, 07:13 PM
  #131
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Man that motor looks great!!! I love it when people build the motors so clean. Clean means done right in my book.
Old 08-31-13, 07:31 PM
  #132
gerrb
Super Moderator
gerrb's Avatar
the dude is clean freak .. lmaol .. you have no idea
Old 08-31-13, 07:34 PM
  #133
JesLet
JesLet's Avatar
Lol, freakin Gerry.
Old 09-01-13, 11:41 AM
  #134
lilSCsteve
lilSCsteve's Avatar
Jes, man this is an impressive engine build! love the direction you're going with this one.
steve
Old 09-03-13, 09:40 AM
  #135
JesLet
JesLet's Avatar
Throttle body and trimmed cover.
Throttle body wasn't sandblasted, just ran it though with a pneumatic wire brush. Kind of disappointed, didn't matched the manifold/plenum.
Quick Reply: 2JZGTE rebuild
