Tj's 95 SC300 1jz Swap
#286
Shoooot damn thing isn’t running. Long story short I noticed my o2 sensor wire wasn’t connected. HMmm I said this is why I’m probably getting a AFR reading of 13.4. So I plugged it in, turned the key to ACC and saw white smoke by the ECU!!!!
WTF right? I open the hood realized the wires were smoldered together from laying on the DP causing a short to somewhere.
I had an extra ecu laying around and for good measures had it rebuilt from Gellar on FB. Car still won’t run correctly. Definitely believe the IACV is done
#287
damn that sucks homie. yea im having some electrical gremlins myself. gotta stupid battery drain coming from somewhere and my headlights dont work. its been too cold to get out there and figure it out. once it gets warmer im going to rip apart the fender harness and double check everything. i was thinking about getting another shell and swap everything over.. This one is clapped lol. it has to be 95 and under because im not trying to deal with emissions and inspection.
