Build Threads Details on Club Lexus 2GS owner vehicles
oil leaking some where i cant locate?
Old 02-26-14, 05:00 PM
BugEyeLex
BugEyeLex's Avatar
Default oil leaking some where i cant locate?
Hi my name is Ryan, I'm a new member to CL and thought it will help with my build n fixes. I have a small oil leak that I think is coming from the oil pan(maybe a gasket change?) but I smell a small oil burn by the engine. What might possibly be the problem? Yr200 btw
Old 02-26-14, 08:03 PM
ttaylor993
ttaylor993's Avatar
Most leaks usually end up dripping from somewhere near the oil pan. If you smell it burning, its probably hitting the exhaust manifold. I'd start with the valve cover gaskets. But, we really need more information before anybody can give you an informed opinion. How many miles on it, when was it last serviced, how has it been maintained, etc. Pics would help too.
btw, welcome to the club!
Old 02-26-14, 09:00 PM
Agent0024
Agent0024's Avatar
Get a UV dye kit for your fluids and find it.
Old 02-26-14, 09:17 PM
mk2tmr2
mk2tmr2's Avatar
Valve cover gaskets, cam seals, VVT-i pulley. <--- most likely culprits.
Also...this is not a build thread.
Old 02-28-14, 01:11 PM
BugEyeLex
BugEyeLex's Avatar
Its a 2000 w/152000miles.it looks like oil. from the bottom of the engine, by the oil pan. Just bought the car and don't really know when the last time its been its been worked on. Hoping its something simple.
Old 02-28-14, 03:49 PM
nezlyfe
nezlyfe's Avatar
You should probably move out of the build thread. Welcome to CL and check the valve cover gaskets as mentioned. if you just bought the car and don't know the history a spark plug change may not be a bad idea (plenty of diys here). if you don't find any oil top side then check the oil pan gasket but generally it seems most leaks are topside.
Old 02-28-14, 07:02 PM
ttaylor993
ttaylor993's Avatar
Almost all leaks will eventually be pulled down to the bottom of the car by gravity and appear to come from the oil pan gasket. It is possible that the oil pan gasket is leaking. However, it is not that common on these cars unless you have bottomed out and hit something. Much more likely culprits are the ones mentioned by mk2tmr2, cam seals, cranks seals vvt-i pulley, especially with those many miles. If you are not familiar with the history you probably need to have all that replaced anyway, along with the timing belt, water pump and ball joints.
gsean400
02-16-23 01:52 PM
SpencerT
08-12-12 11:08 PM
Jmai22
GS - 1st Gen (1993-1997)
06-04-10 01:12 AM
GS300 I6
03-07-10 11:40 PM
alvin
04-10-02 08:14 PM
Quick Reply: oil leaking some where i cant locate?
