JDMV8 "Build" Thread/Progression: Dec. 2011 - Present
#76
Hi guys. I just got back from vacation last week (didn't fit in the dyno before leaving), and I sent out my steering wheel for alcantara work. Waiting on receiving it, and then the ECU has to re-learn since I disconnected the negative when taking out the wheel.
Butt dyno says gains, but numbers will tell. I'll give the car an ample amount of cycles so when I do go to Rafi, the car's parameters are all in check.
Here's the wheel!
Looks great, done by Dallas Custom Steering Wheel.
Here's the wheel!
#78
Cool, will mark it on the calendar for a follow up on your numbers, a lot of guys are anxiously waiting on the outcome!!??
By the way since you've had time to go through some miles with the tune and 100% E85 what does the gas mileage look like so far??
Thx
Thx
#79
I did a cursory calculation and E85 is 1 cent per mile more expensive than 93 (for southeastern PA).
#84
I think I'll add to the fleet before getting a supercharger ...just looking for the right car periodically
You're lucky you found an alcantara interior, I love them. I'll be getting a driver's racing seat eventually...
Update: the current E85 map didn't make any power on top of 93. However, there are adjustments Rafi will make. Next dyno log and tune session is TBA.
#87
E85 testing concluded today. We found that the car didn't make more than 93. When temperatures dropped (mid-Atlantic US), the car wouldn't start for a week.
The car felt "peppier" the instant I went back to the 93 tune. I found that the most optimal fuel I've used thus far was ~1:4 e85/93 mix (16 gal in tank--3/4 gal e85; the rest 93). I base this on butt dyno + how the car behaved (idle/WOT).
On e85, startups were pretty painful...
The only benefit I see to e85 on our cars is reducing noxious emissions. I'm not sure if that is a primary incentive for people driving high horsepower, most-of-the-time de-catted cars.
#88
Agreed on the above statement, my blend for the past 8+months has been between 4-5 gallons of E85 with 91 out here and my car runs like a bat out of hell with my mods!
#90
I tapped the rain sensor for a Valentine One, paired with a Blendmount
We were hit with a blizzard here, so I decided to finally get to installing and wiring MY12 headlights. Wired w/a relay for 50% w/low beams, and 100% always on otherwise.
