specONE Build Thread
#63
still trying to sort through the elevel sensors over the last couple of weeks, still trying to get dialed in so It will auto calibrate and get some presets in hopefully soon.
running the wires out the spare tire well
down the bottom<br/>
all tied down and done
bottom tied down well too
hole drilled in the control arm ready
nutsert
nutsert with the tool
front control arm nutsert in place
front driver
rear
front passenger
Here are some videos of me checking to make sure the sensors mounted are working properly at all angles of the suspension travel.
also today got '15+ factory optional spoiler on. loving this spoiler so far!!!
Link to purchase the spoiler if you got Nebula Grey like me
part number PT938-53140-21
http://ebay.to/2ECBEWV
nutsert
front driver
rear
front passenger
#65
the wing had studs but i popped them off and only used the double side tape to hold it into place. its a pretty light wing.
#69
Thanks
what wires? for the accuair air suspension management?
slightly more aggressive compared to stock wheels? do you have a car on air? I will be selling the Volks and doing different set of 19" with same tires but different offset and widths.
#72
front, i did nutsert into the car as well for only one of the mounting holes. the other hole towards the bottom for the sensor went right through so i just bolt and teflon nut it into place. Easy to take out and easy to put back in without causing holes to strip out from on and off. the wire holders i did just shot regular screws for those.
JayRoman46 (08-13-19)
