in due time, in no rush.
still got plenty of other stuff to work on such as the AMP SUB setup.
Originally Posted by xpandabl3
I'm still patiently waiting for your sub install :P
Originally Posted by SanDeezy
Ditto
wow you guys, totally forgot i even had the sub and amp due to how busy i've been with other projects away from car as well. Thanks for reminding me. I'll try to make some time to start on it next month.
Worked on removable magnet mount license plate for the front bumper.
The super strong magnets I'm using
it fits perfectly into the OEM plate holder mounting holes
Both pressed into place. License plate will hold them in place and do not even need to glue or tape them down.
Marked on back side of bumper where i will dremel through plastic so that the magnets sit on the actual grill plastic so the magnets will be stronger hold
dremeled through bumper, this part will never be seen that it was cut
Double sided taped and wrapped the magnets so they dont accidentally seperate
Strong N52 Neodymium Magnets Rare Earth Round Disc Fridge Craft 20mm diameter fit perfectly into the Hole in the license plate bolt mount recessed portion.
used an assortment of thickness to fill up the hole and stacked them to give them even more strength.
Had to cut into the hidden part of the bumper so the magnets have more pull and be closer together. Initially had it just double sided taped to back of bumper but then the magnets had about 3 layers of plastic to magnetize through so it did not feel as strong.
planning to put foam on the back side of the plate mount so it wont scratch the grill up while "mounted"
thats pretty damn cool. where did you get those magnets from? i too live in cali and this would be really good for poping the plate back on when i need when i get out in the city lol
Finally finished wrapping center console with Black Brush Aluminum Look vinyl wrap to cover the scratches made plus also match the Mark Levinson stereo finish.
Up next DEI 1-mile Remote Start Pager alarm with Glass break and proximity
sensor
all the pieces...
Main Module with harness plugged in.
started cleaning it up with only the wires needed. <br/>will clean up some more once i know for sure where things will be going to in the vehicle as well as double checking wires needed
