My GS400 modding journal - commenced Feb. 2003
#256
Former Sponsor
Originally posted by RMMGS4
Congrats Hameed !!
I never looked much into HRE wheels until I saw them in person. There's just something about these wheels in real life that pictures just can't do justice.
Congrats Hameed !!
The ones that I saw were the regular series (with the stepped lip), and to be honest, thats always been one of the features of HRE (and other hi-end modular wheel companies) that I liked! I think the stepped lip looks classy!
#257
EV ftw!!!
Originally posted by DrewGS4
Very sexy wheels hameed. Congrads on getting them. They really look nice. Do you notice any difference with milage and speed penalty?
I am thinking of getting rims and you guys increase the pressure to do so since everyone is getting wheels.
Still holding back hoping to get a deal on a nice used set.
Weight and and speed penalty? The rims weigh 22 lbs (as opposed to the 26.5 lbs of the OEM 17" chromes). Not sure how much more the ZR rated tires weigh compared to my previous All season stockers, but the car actually feels peppier.
Yeah you definitely need to upgrade your rims asap!
#258
Originally posted by Hameed
I tried to capture the aggressive offset in this pic: (I will post better pics later today):
try to shoot a pic with a yardstick up against the top and bottom of the tire and the top of the wheelwell lip at the same time.
Different picture angles are sooo hard to tell what your offset is. I'm gonna bet that the rim top/bottom and the fender lip almost match up even or maybe less than a 1/4 in gap between the three.
Do front and rear too please.
#259
EV ftw!!!
Hameed,
Hameed,
#260
I don't quite understand what you would like me to do ..........................? Please elaborate a little more and I will gladly do that!
#261
I should of had a second ruler measuring the distance from the rim edge to the yardstick. I can tell you the gap is about 1/4 in. That's about as far out as you as you can go with moderate trimming done to this IS fender shown. The offset is I believe 45 on a 19x9 with 255/30 tire
You might be able to push the wheel out another 1/8 inch further if you trim the fender lip completely off.
I'll try to get my GS photo shot done later.
#262
EV ftw!!!
Look at this unbelievable offset on the front! The top part of the stick does NOT even touch the fender!! It's hard to see that in the photo, however if you look at the bigger version, you probably could:
Bigger version of the pic above:
Here's the rear offset. This one touches the fender at the top:
Bigger version of pic
I don't really like these pics. I will take some better ones tommorow
#263
haha yeah, the offset are very aggresive man. i have a feeling though, if you lower the car with flex to 1 finger gap, you might rub in the front a bit. if so let me know, i have some tricks and tips for you. i have pretty much fixed my rubbing problem in the front (which was pretty bad)
the rear looks good too, though the thing with 440r series is the less lip in the rear
#264
The One
#265
Originally posted by Neo
I don't know rominl. Unless his camber goes negative and the wheel can go inside the wheel well, he is still going to hit the fender on compressions. Unless you are talking about more agressive measures than what I saw you do to your car.
#267
Hopefully.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Hameed will definitely need some work if he plans to drop it.
Hopefully.
#268
EV ftw!!!
Henry, please post your tricks and tips here so that others can benefit from your experience!! Thanks!!
The rear lip is almost three inches Henry. Between 2.5 and 3 inches.
#269
I most DEFINITELY plan to drop it with the Flex, to 1 finger gap in the front. The rear is at 1 finger gap already so I will probably leave that the same as the current L-tuned drop.
Henry, please post your tricks and tips here so that others can benefit from your experience!! Thanks!!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
