My GS400 modding journal - commenced Feb. 2003
#321
EV ftw!!!
Originally posted by bluelex
dude u'r car is slammed in the rear....i say do the brakes next
I want to do the EDFC myself this weekend - at least running the wires through the car and then find a mechanic to do the power wiring to the control module.
Any DIY out there for the EDFC install?
#323
Way to go Hameed! At first I didn't see that the first few pics were 'before' so I thought 'gee it doesn't look lowered that much' and then I realized they were before and could compare with the after pics. It would be great if you could get after pics from the same angles as the before ones and maybe post them before/after before/after in pairs to make it easier to compare if you know what I mean.
The after pics look really great. What size/offset are your rear rims by the way? Mine are closer to the fender it looks like but it's hard to say.
I'm also really glad you like the ride so far. Now when you say you set it to 6/8 you do know the 'actual' measurements are *** backwards from the way EDFC measures it? How did you measure the turns?
Good luck with the EDFC install! Looks like a HUGE challenge getting any cabling through the firewall in the engine bay - be careful.
And those brakes are gonna boggle your mind. I don't have drilled rears yet, are those StopTech rears you have? I'm considering Brembo drilled rears, steel lines and Axxis Metalmaster pads. I also plan to replace my front pads with Axxis Metalmasters instead of the 'ultimate squeakers'.
#326
EV ftw!!!
- F - 18x8.5 OS.31
- R - 18x9.5 OS.37
- Weight: ~ 22 lbs. Ea
- 245/40-18 for the fronts and 275/35-18 for the rears (Bridgestone Pole S-03's)
The pics don't do justice to how the wheels really look. They look much better and much more agressive in person.
After driving around yesterday I found that setting to be too hard. I could feel every undulation in the road and bad sections were just too noticeable. So I changed it to 8/10 when I got home but have not driven it yet. I will post impressions tomorrow on that setting.
I got SS lines for the rear as well with EBC green pads as well. So I essentially got everything for the brake upgrade:
StopTech 14 inch big brake kit (this included of course, the 14 inch rotors, 4 piston calipers, Axxis Metalmaster pads, SS lines)
StopTech rear drilled rotors
The only component not being replaced are the rear calipers.
#327
EV ftw!!!
Originally posted by rominl
that's not slammed, he should go lower!
#328
Congrats Hameed. I too was like it doesn't even look lower then you posted the after pics
lol
Anyways looks good, I say do the EDFC next! Those brakes are huuuuugggeeeee!
#330
EV ftw!!!
After driving around on 6/8 (meaning turning the adjusting screw six clicks anti-clockwise from the stiffest position), I found that setting too hard.
So I changed it to 8/10 and I still find it too hard. What setting do you guys recommend it I set it to so that it has the same or approximately the same comfort level of the L-tuned suspension . (I am assuming that the handling will still be better than the L-tuned at that same comfort level).
What I feel is the real benefit of this mod is the height adjustability, the handling improvement (over L-tuned ss) and of course the shock damping adjustability. Now I need to figure out what settings I need to set the shock damping to so that the ride is not so hard. I am sure I can reach that compromise of comfort and great handling. There is ZERO body roll even at 8/10!!!![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I had to swerve left very quickly to avoid having a collision going through an intersection when someone turned right in front of me and all I can say is WOW - regarding the car's stability during that sudden change in direction. The car felt very planted and solid!
