My GS400 modding journal - commenced Feb. 2003
#406
exclusive matchup
Originally posted by bitkahuna
Hameed - Don't ya just love how the rotors fill up the open spaces in the rim now (compared to stock)?
On a more serious note, I'm assuming you did the break in process? Nuum did that for me thankfully (I don't think my neck would have survived the whiplash ). If you did, how'd you find a road appropriate to do that in your neck of the urban woods?
#407
exclusive matchup
Originally posted by FutureGS400
Oh great, another "must have" mod for my GS!
Are the rear rotors stock diameter and use the stock calipers? Do you mind telling us what they cost you?
Really looks good!
Really looks good!
#408
Hameed,
Buddy who did the brake work for you?
Doesn't look like Erin Park Lexus but I don't go there too often anymore either.. Lemme know since I need some brake work done to my ride too..
#409
EV ftw!!!
I just assumed the break-in procedure was not to apply the brakes hard enough for the ABS to kick in for the first couple of hundred miles? I have noticed that there is a strange deposit on the front rotors - see attached pic
Really looks good!
Really looks good!
Originally posted by Neo
There was no way that 56k warning was going to keep me from opening up this page. I'm visiting family now and they only have dialup. Had to see the pics though.
Very nice Hameed. Congrats.
Originally posted by rominl
same here, my cosmetic is done, next would be performance and audio
but that means you don't want to keep your tte lip for long then? why? i actually like your tte lip more
#410
EV ftw!!!
Originally posted by 2SAVVY
Hameed,
Hameed,
Originally posted by Hameed
My local Lexus dealer's Master certified mechanic - Desmond did the install for at a small place he rents after hours to work on friends car's and my cost was very low - $200.00 (canadian dollars - about US$150.00)!!!! Desmond is DA MAN!!!! (the guy in the pics is Desmond). The whole job took only 2.5 hours and he did an absolutely flawless job. System was properly bled and he did not have to do anything special with regards to bleeding as Paul (Bitkahuna) experienced with his StopTech set. Maybe mine were slightly different....
#411
Please enlighten me about the break-in procedure. I have absolutely no clue what that is..........
#412
Forum Administrator
Hameed,
Interested to know if you hear any noise from these brakes (or other folks that have them) similar to what I hear with the Supra TT brakes / rotors. Its probably too cold to drive with your windows down and listen (that's the only time I hear mine, sounds a bit like a bike with a card in the spokes) for any sound when you drive past a wall or other reflecting surface. I'm never sure if its just the drilled/slotted rotors or if just drilled would do it too.
Did you paint your rear calipers black too? Can't quite tell from the pics.
#413
EV ftw!!!
$#!+ !!!! There's big warnings in the manual for the big brake kit about breaking them in properly. Please read and do this! I think ya gotta do 10 REALLY hard brakes from 60 to 5 mph (not stopping completely) in a row. Yes the brakes will get hot and smoke. That's normal. Anyway, RTFM!
#414
EV ftw!!!
#415
EV ftw!!!
Paul, did you noticed the pic I posted above? It is a bit hard to see the deposit in the pic, but the rears are absolutely clean compared to the fronts as shown above.
#417
I'd say the deposits are just the brake dust building up in the drilled holes in the rotor. You dont see much(if not any) in the rear rotor yet because about 3/4 of the braking in done with the front brakes. If the holes get clogged with too much dust, the holes wont do as good of a job of dissipating heat, thus increasing your chance of brake fade...thats my two cents Good Luck and Congratulations on the awsome brake setup _Will
#418
exclusive matchup
In other words not hard enough for the ABS to kick in but hard enough to almost stop? OK, I will do that today! What are the negative consequences of not having done this already? I have driven it for about 120 miles already...
you need to find a stretch of road and drive like a mad man for like 10 to 20 times. accel to 60-70mph, then literally HARD BRAKE (stand on the brakes) to stop the car. VERY hard brake, i mean it. to about 5mph, then repeat.
aftwards you should get ALL sort of smell from the wheels, and you should see massive smoke coming out of the brakes. oh and it will be stupidly hot.
that's how you bread the pads and the rotors and make them start doing their job.
boy... and now your whole brake system is broken already, including rotors, calipers, and pads... sigh, just send me yours and you can order a new set!
#419
EV ftw!!!
oh man, hameed, how can you NOT read the instructions.... that sux man.... the break in process for the brakes are as important as you can imagine.... damnit....
#420
EV ftw!!!
Originally posted by Mr Johnson
As Tony the Tiger would say... "They're GREAT!!!".
Very Nice
Very Nice
