RoyalOrigin x BossCompany 2003 GS300
I'm pretty sure I replied to your answer yesterday but now I can't find it.
Let's try it again then.
That is alot of camber with the stock arms. I thought the maximum negative camber in the rear was -5 if that. You sure you were all stock?
Originally Posted by johhntran
it was all stock arms, shaved rears and rolled fronts. camber was maxxed out at -4.6 front and -6.9 rear
*edit: woops forgot to mention the toe
im really trying to save for air suspension and possibly an aimgain kit?
im from oc, i dont think my car has seen that area before haha
thank you!
got the junction produce fusa and tsuna for my bday a few days ago
i also installed the 30mm camber rca, it gave my fronts an additional -4.2 degrees of camber
i managed to pull -8.9 in the front and -6.5 in the rear with all the toe dialed in
the front lip is now destroyed because the rca corrected the suspension and also allowed me to lower it further
i also went to the Lexus of Westminster meet yesterday morning, quite fun... shout out to qtrann even though i didnt get to meet ya
That's alot of camber in the front. Almost too much for my liking.
Rear end looks like it drags lower than front but I think it's just because the wheels are tucked.
You got the Sage front RCA? I assume you got the additional camber from lowering it even more.
The frame rail is actually lower in the front than the rear, it's just the actual fender arch is smaller in the rear. I have studio camber rcas so it offsets the hub while the sage rcas are straight drops
