Build Threads Details on Club Lexus 3IS owner vehicles
Ultra White/ Rioja / 350 AWD
Old 12-24-14, 07:00 AM
  #46
NVMarkus
NVMarkus's Avatar
Originally Posted by KumaF
Thanks man. Now I think I will go with 19 instead of 18.
No problem at all, I have a few friends on here that have the same size rear tire and do not rub, they just have a higher offset than the 38 I have, I believe some have a 42 and 45, some of the New Vossen wheels have a 48 on the rear so the tire really tucks under nicely. In fact I think I am going to switch to the Vossen. If I could run a 265 or 255 on the rear tire of mine It would be great...
Let me know if you have any questions I would be happy to help you out....
Old 12-24-14, 01:03 PM
  #47
KumaF
KumaF's Avatar
I kinda want to go with a square setup with 19x8.5 et 35 all around. I could go with staggered front and rear, but the rear only comes in 19x9.5 et 40. Not sure if that's gonna rub, since the offset is only 2 mm higher than yours
Old 12-24-14, 03:17 PM
  #48
NVMarkus
NVMarkus's Avatar
I know for sure with my wheel being a 9.5 et38 I rub with the 275 rear tire, and it is not a lot, it just barely does, so with the smaller rear wheel, and a couple mm you would probably be good to go
Old 12-26-14, 06:11 PM
  #49
albertgoq
albertgoq's Avatar
Hi NVMarkus
Can I see a side shot of your rear wheels to see how a 9.5 +38 w/ 275 wheels look like?
I bought the same wheels 18" only though with the same offsets +38 still deciding on 255/265/275 width so to prevent rubbing.
Thanks!
Old 12-26-14, 08:30 PM
  #50
NVMarkus
NVMarkus's Avatar
Here you go...
Attached Thumbnails Ultra White/ Rioja / 350 AWD-image.jpg
Old 12-26-14, 08:48 PM
  #51
NVMarkus
NVMarkus's Avatar
Old 12-27-14, 05:26 AM
  #52
albertgoq
albertgoq's Avatar
Thanks man! 😄
Would u think if I go 265/35/r18 then it would clear my fenders? Same rims work cr-kai/kiwami 9.5 x 18 (mines 18" though)
Old 12-27-14, 10:12 AM
  #53
NVMarkus
NVMarkus's Avatar
Wheels: Wheel 1 Wheel 2
Wheel size 19x9.5 ET 38 18x9.5 ET 38
BackSpace 171 mm (6.7'') 171 mm (6.7'')
Tires: Tire 1 Tire 2
Tire size 275/30-19 265/30-18
Section width 275 mm (10.8'') 265 mm (10.4'')
Sidewall 83 mm (3.3'') 80 mm (3.1'')
Tire diameter 649 mm (25.6'') 617 mm (24.3'')
32 mm (4.9%) shorter.
I would say with the extra .4 inches and smaller height you should be good to go...
Old 12-27-14, 03:54 PM
  #54
albertgoq
albertgoq's Avatar
Thanks again 265/35/r18 it is, will it look stretched on a 9.5 rin?
BTW what wheel specs and offsets you have up front?
Old 12-28-14, 08:28 AM
  #55
NVMarkus
NVMarkus's Avatar
235/35r19 with et35 no rubbing whatsoever...
Old 12-28-14, 05:11 PM
  #56
wthrman2
wthrman2's Avatar
Received 3,686 Likes on 1,784 Posts
Just a question as I am curious. Could one remove the piece of plastic in front on the rear wheel. I know it is there to prevent rock from chipping the paint but I hate how it shows a distinct line around the edges. It would look as bad if the plastic tape gets pitted anyway no?
Old 12-28-14, 07:14 PM
  #57
NVMarkus
NVMarkus's Avatar
Yes, it is just like clear bra, the factory puts it there to protect the paint, being that I am sure they ruined some cars without it... You know that is a high impact spot if the factory includes it there...
Old 01-04-15, 05:28 PM
  #58
wthrman2
wthrman2's Avatar
^^ Thanks for the answer. I agree that they must have placed it there for a reason...I will decide whether to leave mine on when it arrives.
Car looks great by the way....nice mods that's for sure!
Old 01-04-15, 09:11 PM
  #59
NVMarkus
NVMarkus's Avatar
When you first get it, it is not as noticeable, need to clay it to clean the edges again...
Thank you!!
Old 01-13-15, 05:31 AM
  #60
NVMarkus
NVMarkus's Avatar
the X pipe is on the way, soon to be installed for my JoeZ AWD Cat back :-D
Quick Reply: Ultra White/ Rioja / 350 AWD
