Build Threads Details on Club Lexus SC owner vehicles
Jzx100 1jz VVTI swap 96 Sc300
Old 07-03-14, 12:02 PM
HkmttaSc3
HkmttaSc3's Avatar
Exclamation Jzx100 1jz VVTI swap 96 Sc300
Whats up guys..
Okay guys as the tittle says i feel that it is swap time ^_^, i have used the SEARCH button before anyone starts to flame me for that but i can not come to conclusions on the question that are running around in my head. so i have a couple questions to ask and hopefully someone can answer them for me Plz and Thnk you in advance.. Also if you have personally done this swap by yourself i would appreciate a conversation with you lol.. so here it goes
1. What parts can i take off of my 2jzGe that will fit on my 1jz , 1 bearing was spun on the motor and its going threw a rebuild right now, Can i use Ge bearings on a GTE, will a GE head gasket work on the GTE, or should i go with a different one?
2. The wiring harness is missing a couple plugs and it looks to have been smashed at some point in time, is it better to replace plugs and wires that are F*d up or should i just buy a Soarer VVTI harness/ecu and go from there?
3. i am missing the stock BOV and Oil pick up (i think it is) were can i get the oil pickup from and what is a good replacement for the BOV or should i go back to stock??
4. I also need a VVTI Harmonic Balancer and the (TIming Gear) i think its called if anyone has one i would like to buy..
5. Does anyone have extra OEM parts that they might not need?
i do have a lot more questions but i will save those for later these are the main questions i have right now that will at least get my motor back together lol..
Old 07-03-14, 02:44 PM
Tabaka
Tabaka's Avatar
1. Every accessory including the clutch fan, water pump, power steering pump, and the AC compressor can be swapped. I believe the oil pump and alternator are different.
2. Replace the plugs and connections. Why spend extra money on a new harness?
3. Driftmotion, get a HKS, Tial, or Blitz BOV. Only authentic as the knock offs will leak.
4. Harmonic balancer is the same from the GE and GTE engines.
5. I might have some extra stuff, what do you need specifically?
Old 07-06-14, 04:33 PM
HkmttaSc3
HkmttaSc3's Avatar
Thank you very much for the info.. and for the parts you "might have" mind if i pm you for some details on the stuff??
lex1220
Performance & Maintenance
12-15-11 07:38 AM
wilsonsan
GS - 1st Gen (1993-1997)
04-11-11 01:06 AM
96sc
12-02-07 01:44 PM
1992 SC300
05-25-07 07:20 AM
FormosaSC
04-11-07 08:16 AM
Quick Reply: Jzx100 1jz VVTI swap 96 Sc300
