RSpec Project GS350
I'm surprised that the SL Disk cleared the F sport brakes too. I got CV01 with NR disk +44 offset and SSR rep told me I had to get 5mm spacers for the front to clear the brakes. My wheels have been sitting around since end of July. Need to install ASAP after seeing your car. Sick, dude! Just sick!
I'm also interested in a coil-over and cup kit set up. Maybe I'll consider an authentic lip if I'm able to raise my car on the fly since I daily my car. Looked into Air Runner/Accuair set-up but not willing to drop 7k. I'm currently on Tanabes and I still can't clear some dips that lead into a ramp here in Houston. Someone on the forum mentioned a company that's developing a coil-over that will retain the AVS function.
Lastly, I want to buy the red center caps. Is it bright red or more dark? I bought some kics leggdura racing lugs in red and would like the center cap to somewhat match.
The company is called Exotic Air. Its about $3100 for the front cup system with basic air management. It comes with 2 cups, lines, compressor, tank, paddle switch, and wiring
Yup SL disk works perfect for our cars. Actually SL works better then NR because SL is a super concave while the NR is flat, so you would need to get a higher offset. Don't believe any reps lol they don't own ours cars. So they don't know the measurements lol. Have you already test fitted your wheels? I don't think you need spacers unless your trying to make your rim flush.
Yeah, I love my coilover and cup kit set up. I got this because I wanted to keep the benefits of a coilover setup like handling and to be able to drive fast. Also I love the added benefits of raising the car and never worrying about the rubber parts blowing or if it fails I can still drive it home
Yeah the center caps are bright red. Just looked at the pictures for project kics and I think they will match
T-Demand Upper Arm
Just got my T-Demand front upper arm. Still waiting for the rest of my suspension parts from them. There are two version for the upper arm Oni-Camber which is -55 to 0 and Semi-Camber -45 to +10. I love the demon camber look so I choose the Oni. Its an expensive piece, but you can tell its worth it. The welds and the finish on the arm is awesome.
Nice choice of rims 9.5 would be good, but you would probably have to do a small roll depending on what face and tires you get.
