Build Threads Details on Club Lexus 2IS owner vehicles
Redspencer's Track-Tuned IS350 w/ OS Giken LSD Build Thread
Old 08-12-16, 12:54 PM
  #211
redspencer
OG Member
redspencer's Avatar
Originally Posted by codenko
He should be fine. I'm running 255/35/18 on my 18x9 +45 PF01's on the front with no issues. I am having the run a 5 in spacer to give myself a little more clearance from (whatever the bar is called that goes from the UCA to the hub). Not sure if it's necessary...but it makes me feel better lol.
Thanks for the feedback. I was basing my analysis from another CL member, Sportskid1, on his experience with using 255/35/18 with the same wheel specs for the front and not having any rubbing issues.
Originally Posted by Sportskid1
Finally burnt through my old track tires and found a nice set of 255/35/18 R888 take offs for a cheap testing setup. Mounted them up and gave them a test fit in the front. Complete success in the initial install and an afternoon of driving around town. Tires sit about 1/4" inside of the fenders (Near flush). No rubbing at all from lock to lock. Nothing hits on speed bumps and as of now I would say I could live with them as my daily driving wheels (these are track only wheels). I haven't done any aggressive driving yet but hope to get to the track in a few weeks for a full go at it. So glad they fit. I will be so nice to have the ability to rotate from front to back. My tires will last so much longer. Here are my stats if anyone is interested
18X8.5 +35 Wheels
255/35/18 Toyo R888 at all 4 corners
Running about -2 deg of camber up front
Lowered to about 1.5 finger gap ob BC coilovers
Glad to hear that you too have no problems running this width on the front as well. Michelin Pilot Super Sport tires tend to be wider than most other manufacturers but I think the diameter of the tire has more of an impact to rubbing issues than the width of the tire.
I still have to do more research on whether or not 275 width tires on 18x9 +35 wheels will rub on the fender edges in the rear but so far I haven't read anything to dissuade me otherwise.
Old 08-12-16, 07:32 PM
  #212
Gville350
Gville350's Avatar
At your ride height, I think it'll be very close with those 275s. With the 255s on my 19x8.5s with a 30 offset, I've got a 7mm clearance between the fender inner lip and the tire (BFG KDW II, runs narrower that PSSs). I'm tucking these bad boys of course.
Old 09-01-16, 05:19 PM
  #213
redspencer
OG Member
redspencer's Avatar
Nearly 30,000 amazing miles have passed since I've had the OS Giken Traction Control Differential (TCD) so it's about due for some fresh differential fluid. At 50 bucks per quart, the 80w-250 differential fluid definitely makes the wallet feel a bit lighter.
I also picked up some new ATE Type 200 brake fluid since I'll need to swap this out in the near future as well.
Old 09-02-16, 12:40 PM
  #214
Gville350
Gville350's Avatar
Curious what do you use to flush the brake fluid?
Old 09-02-16, 01:11 PM
  #215
redspencer
OG Member
redspencer's Avatar
I'll be taking the car to a tuner shop for the fluid swap (since I also plan on getting the rear fender rolled) so that's for them to take care of.
Old 09-11-16, 07:30 PM
  #216
JDMV8
JDMV8's Avatar
Great IS
You've modded it correctly for sure...
Old 09-12-16, 05:13 PM
  #217
Gville350
Gville350's Avatar
Ah, very good. If I end up ever going with 265s in the rear I'll HAVE TO finally roll mine.
Old 09-13-16, 01:42 PM
  #218
redspencer
OG Member
redspencer's Avatar
Originally Posted by JDMV8
Great IS
Thanks for the compliment. I've always been performance-minded with my vehicles so I'll take advantage of whatever high-performance parts are available for this platform in order to improve the fun factor.
Are you still using BFG KDW2s?
Old 09-13-16, 04:41 PM
  #219
Gville350
Gville350's Avatar
^Yep. If I went with 265 PSSs or KDW IIs, they'd rub the fender. LOL! But I've picked up a NOS set of Falken 452s for $200 for the rear (255/35/19) that will be installed before winter. Not the best performing tire; but at $200, I couldn't pass it up! My Federal 595 EVOs up front are still lasting crazy long...all thanks to the RR Racing LCA bushings!
Old 10-01-16, 04:46 PM
  #220
redspencer
OG Member
redspencer's Avatar
I'm currently at West Palm Beach, FL waiting to attend the Lexus Performance Driving School at Palm Beach International Raceway tomorrow. I'm looking forward to driving the RC-F, GS-F, 3IS350,and 4GS350 around the track. I'll post my full impressions of the cars soon.
​​In the meantime, I took advantage of the sunset with my now decade old car which turned 10 years old this week!
Old 10-01-16, 07:24 PM
  #221
Gville350
Gville350's Avatar
Have fun Red!
Old 10-02-16, 05:42 PM
  #222
redspencer
OG Member
redspencer's Avatar
Here's a couple of pics that I took during my time at the Lexus Performance Driving School at PBIR today. The random rain showers and lightning made it difficult to get the groups through the autocross and lead/follow track events in a timely manner.
We had an opportunity to do a couple of autocross runs in the 3IS350 and RC350 F-Sport. The RC350 kept its composure through the course and I had no complaints but when it came to pushing the 3IS350 hard on the course, I was utterly disappointed at how slow it was launching from a dig as well as how much body roll and lack of steering feedback I was receiving with this car in the corners. I can confidently say that a 2IS350 equipped with the F-Sport suspension package and an IS-F Steering ECU can easily run circles around the new model on a track.
Driving the RC-F for a couple of laps on PBIR was a much more enjoyable experience. Even though that portion of the event was merely a lead/follow process and we weren't given the opportunity to push the RC-F or GS-F anywhere close to the limits, you can feel the 255F/275R Michelin PSS tires stick to the track with hardly a hint of body roll. Having the 2UR motor at WOT on the straights was acoustically pleasing as well. Not sure why but the RC-F that I was driving on the track was only equipped with a Torsen LSD and not the higher-performance TVD. Seeing the RCF-GT in person was probably my favorite part of the event.
Old 10-03-16, 12:58 PM
  #223
Gville350
Gville350's Avatar
And they didn't offer your car into the line-up why? LOL!
Old 10-04-16, 04:18 PM
  #224
redspencer
OG Member
redspencer's Avatar
I plan on signing up for an open track day event at The FIRM in Florida for December 10th. Though I don't think my new tire set-up (255F/275R) will be ready by then, my current tires will definitely be fully worn by the time I'm done with a full day at the track.
This will also give me a good opportunity to see how the IS350 and the powertrain handles a full day at the track with the new ECU tune and the 7200 RPM rev limit.
If anyone else is interested in going, you're more than welcome to join in on the fun!
Old 10-04-16, 06:23 PM
  #225
Gville350
Gville350's Avatar
Looks like fun! Hope its still there after Michael is done and over with!
Quick Reply: Redspencer's Track-Tuned IS350 w/ OS Giken LSD Build Thread
