Redspencer's Track-Tuned IS350 w/ OS Giken LSD Build Thread
#676
I would like to really like to know. Is why is it so beefed up. Does the front end really flex that much? I wish Toyota would have made a one piece TRD like the second Gen GS. I had one, and what you wrote about the strut bar you have. Is exactly what I felt the car do on curves. Not so much on straight aways.
Sounds like you all need a full cage as the body twists so much on its own is stock form. But seriously those braces I posted in the full underbody shot should keep the suspension in check. The upper A-arms have a fraction the load of the lowers. That said the arms themselves likely eat up some response as they are pretty flimsy.
I suppose for pennies on the dollar one could box them in, powder coat and add poly to crispin up input...
C, I am surprised your rear diff only has front solid mounts. Has it been that way since the LSD installation?
#677
Though there is no TRD branded front tower brace for the 2IS, the Tom's version is available which is kind of like TRD.
1) F-Sport Rear Under Chassis Brace: Easily a night-and-day difference in reducing the polar moment of inertia with steering and chassis responsiveness. It's easy to see why this was the sole chassis brace offering from Lexus USA/TRD USA with the F-Sport Accessories package.
2) Four Point lower tie brace: Another excellent chassis brace to further improve steering responsiveness from the chassis. It ties the lower control arms to the chassis.
3) Front Tower Brace: As much as I have been skeptical about putting a strut bar on a vehicle with a double wishbone suspension over the years, I found having a solid single piece brace does provide additional improvement with steering responsiveness and assisting with the distribution of load when initiating a sharp turn. It should certainly help more than the three piece strut bars with pivot points.
The rear end feels stable and I don't notice any wheel hop when I launch the car from a dig so I'm guessing the more critical bushings to upgrade are in the front (though it's still recommended to upgrade both the front and rear now that diff bushing kits are available).
#678
On the topic regarding suspension tuning and setup, I saw this very interesting video earlier today with puts an E39 M5 on a front suspension testing rig in order to put the components and tires under extreme stress (which appear to be under track conditions based on the acceleration, deceleration, and cornering behavior):
#679
Someone is selling the RR on Ebay modified somehow. Not really sure. I messaged the seller did it really improve handling, and did the chassis flex that much. Response I got was a video link on how strut bars work.
#680
That used RR strut bar doesn't look as purdy as the ones shown on the website (it's also missing the carbon fiber inserts as well). For the price though, it's not a bad compromise. However, I do recommend getting the F-Sport rear under chassis brace and/or the lower four-point tie down brace before getting a strut bar as those are more effective based on my observations.
On a side note, the mod bug has begun with the IS350C. I won't post much more on this car as I don't plan on adding an extensive mod list to the convertible like with the IS350. However, the stock vacuum cleaner intake sound of the factory setup was driving me nuts (too sedated) so I went ahead and installed both the F-Sport lower intake box as well as the 3IS350 F-Sport intake pipe with Sound Generator that I had laying around the garage.
It's a simple mod using OEM parts to maintain the whisper quiet setup at lower RPMs and adding a bit more growl and rumble at the higher RPM range. Here's are a few pics of the install process (the IS350C only has 35k miles so the engine bay is still sparkling clean):
EDIT: On another side note, when I popped open the intake box, I noticed that the engine air filter was a completely different design. Upon further research, it turns out that someone installed the engine filter from the 3rd Gen IS350 into this 2nd Gen IS350C. It still fits but it's a tight fit. I'm debating on whether or not to keep this clean filter even though it's not for the correct generation Lexus IS.
As this 2014 2nd Gen IS350C is of the same year as when the 2014 3rd Gen Lexus IS model rolled out the production line, I can foresee this being a problem whenever I need to take the car in for service (installing wrong parts from a different chassis). It's probably best that I tell a shop to look for parts pertaining to a 2013 MY in order to minimize confusion and errors.
#681
Changing the ride height will alter multiple suspension geometries: roll center, roll couple, roll axis, camber curves, etc. Based on the info I gathered from the IS-F subforums, reducing the height by 1.0-1.5" is optimal for our platform. Without having the engineering data to verify the exact changes being done to the tire contact patch when further reducing ride height, it's difficult to predict if there would be further gains to be had or not. This is a great website to further understanding the science of suspension tuning: http://farnorthracing.com/autocross_secrets5.html
FYI, you can look into attending a Tire Rack Track Night in America HPDE event. It's open to all levels of driving (Beginner to Seasoned) and they regularly host events at PBIR in West Palm Beach (next one is on August 20): https://www.tracknightinamerica.com/
@redspencer Thanks for the info!!!
#682
With the summer heat continuing to make each day feel muggy in Florida, I've been hiding mostly indoors. I did, however, make a few random short videos on my YT channel to pass the time until things get a bit cooler outside for more AutoX/HPDE events. Till then...
EDIT: BTW, I've officially renamed my YouTube channel to Redspencer IS350
#683
#684
BTW, according to the warning on the box, the intake box may cause cancer or reproductive harm.
#685
Just placed an order on oemvehicleparts.com. As I'm also looking for a little more noise up front. My HPS intake pipe does a bit good, but I feel it needs a little more throatier sound.
#686
Take away is CA does not condone explicit air box activities as you may be altered! Lol
#687
All this talk about cancerous F-Sport Intake Boxes had me wanting to do more datalogs which I have been this week. I'm currently testing to see if how much of an impact the hole in front of the F-Sport Intake Box has on both IATs and recorded MAF g/s.
I've already recorded several days worth of data with my current setup and I plan on swapping out the F-Sport intake box with the stock OEM intake box that I have laying around from the IS350C to see if the enclosed box has a noticeable impact to peak air flow and IATs.
The current Florida weather has consistently been in the low 90s with max humidity during lunch time when I did my recordings and should remain the same next week when the intake boxes are swapped out. I'll post the results soon after so we can see if there are any performance benefits or penalties with the additional intake hole from the F-Sport Intake Box....
#688
Since I'm on the topic of datalogs, I figure I would consolidate most of my previous datalogs from back in summer of 2018 and January of 2019 for those that are new to my build thread this year (and for future reference with intake pipe discussions).
Here is a collection of datalogs I recorded when I was testing to see which of the two intake pipes (JoeZ Intake Pipe vs 3IS F-Sport Intake Pipe w/ Sound Generator) provided the highest peak MAF g/s recording (intake air flow) during both summer and winter testing.
The end result was the JoeZ intake pipe consistently having higher recorded MAF g/s readings compared to the 3IS F-Sport Intake Pipe during similar weather conditions.
1) Summer 2018 Recordings
- JoeZ Intake Pipe Datalogs:
- 3IS F-Sport Intake Pipe w/ Sound Generator Datalogs:
2) January 2019 Recordings:
#689
As I mentioned in one of my previous posts (#687), my current plan is to datalog the changes in IATs and MAF g/s readings between the stock OEM intake box (enclosed) and the F-Sport lower intake box (with the additional intake hole in the front). I'll be recording several days worth of data at approximately the same time of the day and the same outside temperature to ensure consistency with the data and the results (and also means plenty of WOT pulls for me).
For the longest time, we've been hearing that the only benefit of the F-Sport intake box is the increase in sound from the additional hole but no increase in performance (with no actual data to back up these claims). The intent of the datalog comparison is to see if there are actual performance benefits to the F-Sport lower intake box (via the peak MAF g/s readings after a multitude of WOT pulls). I've already collected several days worth of data with the F-Sport lower intake box so now it is time for the swap to the OEM enclosed intake box (the question is whether or not it's considered to be an upgrade or downgrade....):
1) Getting ready to make the swap back to the OEM lower intake box (donated from the IS350C which recently received its own F-Sport lower intake box)
2) While I was making the swap, I decided to wrap the end of the intake snorkel with multiple layers of electrical tape to better seal the intake box from the engine bay heat (as the original seal is completely flat and/or deteriorating away)
3) OEM lower intake box is secured (not sure if it was worth sweating in the garage)
On an unexpected turn of events, my car battery reached the end of its 3-year lifespan (it only had a voltage reading of 10.5V). I managed to swap out the battery to a fresh one but now my Knock Correction Learn Value (KCLV) has gone from a strong 23 to the default 15 (which will drastically reduce peak ignition timing advance).
BEFORE
AFTER
This is both a blessing and a curse because the lowest KCLV reading of 15 will also give me a brief opportunity to record the peak ignition timing advance permitted from the ECU while it is at its most retardedest (yes, I made up that word ). From previous datalogs (and a KCLV over 20), my peak ignition timing is at 30 degrees (on rare occasions at 31 degrees) so we'll see what it shows when the KCLV is at its lowest settings.
BEFORE
AFTER
#690
Yeah I hope there is some positive gains in the lower airbox. I'm still waiting on my order. Slowest shipping imaginable.
I used velcro I found at work. For the seal on the snorkel. Still going strong after a few months. Most of the stuff I have used. Would loose adhesivness with in a couple of weeks.
