+1 on some more pics. looks really good as is.. did you experience any rubbing by now?
i'm looking to get 20' CVT for my 3is too and i don't want to change the suspension.
how do you like the ride so far compared to the stock rim and tire?
1. The front rubbed slightly and I heated up the inner fender wells with a heat gun and pushed them in a bit. Seems ok now and this has been mentioned on the forums
2. Yes the back does rub with people in it. I have a fender roller coming and I plan to heat the fenders and roll it out slightly just about 1/4 inch should do it. It won't take much and I should be rub free.
Considering doing RSR Half Down springs. Anyone running this setup with a 275 in the rear (10" with +45)?
Nicely done Love those CVT's. I'm concerned that all 4 corners will rub. Having had 20's on my 2IS with 225-35/20, I was having rubbing issues. That said, I can't imagine the 245-35/20. Also, the rear tires are way too wide. Those are for cars like Mustang, G37, etc. I'm not telling you what you should get as for your tires, but just expressing my concern about possible rubbing issues. You'll need to do some work to avoid the rubbing! Good luck!
I'm in a very similar situation. I have the Niche version of these wheels 20x10 but they are a +40. The tire I went with is a 285/25/20. I want to lower as well but not sure if I will rub?
You may be able to get away with this (with half down springs) however I'm sure it will rub in the rear. You would be surprised what happens when you stick 1 person or 2 people in the back and start taking turns or hit pot holes etc. The rear fender wells are not wide at the bottom and it rubs right where the sheet metal meets the plastic bumper and they're connected.
Having the +40 in the rear vs the +45 I'm sure makes a small difference also you're running a 25 series tire...
