MY 2015 GS350 F Sport - Atomic Silver
if you want my opinion just leave it stock man, the stance is proper, and it looks amazing. If the engineers at Lexus would have achieved better handling by lower the vehicle then I think they would of done it. Unless you know something that the engineers don't, don't mess with the vehicle is my advice. Because I don't know if you read the threads, almost everyone that has moded their cars are always complaining of vibrations and a list of other annoying problems. The GS is a very sensitive car, its a luxury sedan, don't make it something its not.
And im a relatively young guy compared to most of the owners, im 29, so im not a grandpa telling you just leave it stock and just drive. I truly think that's the best look for the GS. Your car looks perfect the way it is..![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Actually, the engineers do not lower the cars mainly due to clearance issues--can't have the general public scraping all over the place. A car with a lower center of gravity will usually handle better, all other things being equal. With that said, lower it with Tanabes or RSR downs. You won't have any issues if you roll on your stock wheels. I am on Tanabes and I drove for about 6 months on stock wheels and had no issues whatsoever (no rubbing). The car handled better but not mind-blowing better (compared to coilovers). Tanabe's spring rate are practically identical to stock springs so the ride is very similar. If you go one size up, just make sure you do your research on offsets and tire sizes. When I changed my front wheels to 20x9 with +39 offset and tire size 245/35/20, I got a slight rub in the front if I hit a dip in the road too fast (over 40mph)--No rubbing on speed bumps, full lock turns, or ramps. You may get the occasional scraping of your bumper if you enter a steep ramp that is preceded with a dip...but this is the life of a lowered car. I hope this helps. Good luck.
I was contemplating going up a tire size on stock wheels, and also the Tanabe springs.. seems like this combo could possibly cause some bottoming out rubbing from time to time. Would this be on the inner or outer tire? Just curious if this could be corrected with spacers, or if custom offset wheels are needed.
I know going with 20's though you would have a slightly larger tire diameter than on a 19, so it wouldnt be an identical setup to what I am considering, but darn close. You never ran a larger tire on your stock wheels with the Tanabes by chance did you?
From your experience though, I may stick with stock tires if I add springs. Or maybe better yet keep the stock springs and just upgrade the tire size down the road. That would fill in the fender gap a bit and likley improve the ride and handling at the same time without worry of rubs!
Thanks again for sharing
Lexus throws larger metallic flakes in one coat, then finer metallic in another coat, so it reflects the light differently on a sunny day vs cloudy days or night time!!
They really put a lot into these paints, and the end result shows!
Hey, thanks a lot for this detailed input here!
Thanks again for sharing![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Spacers would push your wheels out to the fenders giving you a better and more flush look if you choose to just lower with stock wheels. There's a thread on spacers. I don't know the measurements for front and back.
tresmith00
NX - 1st Gen (2015-2021)
18
05-15-15 01:07 PM
