93sc400 with 97+ side skirts trying to swap on 95sc400
I have a 93sc400 with 97 + sides skirts that i want to swap on my 95sc400 but I'm not sure how. As far The doors go. Would it be easier just to swap the doors out with each other? Also on the skirts what will i have to do to install them on my 95? Will there be a need to drill any holes? I've never done this before so any help is appreciated.
Thanks!
93sc400
95sc400
they literally just come off and you put them on the other car, just undo all the screws you see, there might be some on the bottom, there's inside when you open the door in the door sill, in the corners, then there's a screw inside each wheel well, the front one you have to move the liner over and you'll find the bolt, it might be rusty and might break, it doesn't matter though cz the skirt is secure without it. the doors you don't need to swap??? just the trims on the bottom, they're also held with just clips and 2 nuts on each end of the door and they just pop off. just make sure you look for all the screws and nuts you can find and you'll be fine. then putting them on the other car reverse installation, except the bottom bolts you'll need to drill holes but they're not necessary at all so that's up to you.
