Build Threads Details on Club Lexus 1IS owner vehicles
IS300 Aristo VVTI Build
Old 05-13-15, 02:37 PM
Pangoo
Pangoo's Avatar
lol damn any candidates for what car this is going into yet ?
Old 05-16-15, 08:08 AM
antis
antis's Avatar
I was going to purchase a shell today, but it needed to be painted and it had too many parts missing. I backed out on the deal. There is still one more thing on my list before I start looking for a car (Marlin Crawler r154 race rebuild kit from driftmotion). There are many is300 for sale in Florida for decent prices, the car won't be an issue.
Old 05-23-15, 10:13 AM
antis
antis's Avatar
I purchased a GE harness from a 2003 IS and I routed the wires to fit the GTE. I used 3M friction tape to hide all the wires. I love the how the end product turned out.
Old 05-23-15, 10:21 AM
antis
antis's Avatar
Fully built R154 transmission upgrade kit from Driftmotion. Transmission will be dropped off this Tuesday to get rebuilt.
Old 05-28-15, 03:10 PM
antis
antis's Avatar
Last Tuesday I dropped off the R154 at Brevard Discount Transmission and Auto Center in Merritt Island Florida for the rebuild which was done by Chris. The R154 is ready to be picked up. Here are some pics of the process as he worked on it.
I got this tranny at a good price but it was sold to me as a fully working transmission(craigslist). Clearly we can see a broken shift fork. Great thing I decided to do this rebuild.
The stock bearing retainer vs the Marlin Crawler HD bearing retainer.
Old 05-28-15, 04:43 PM
Reidel70
Reidel70's Avatar
Default IS 300 engine swap
can anyone recommend someone in the san Antonio texas area to perform an engine swap on 02 IS 300 to an Arista VVti. have the car and engine but need the mechanic. any help or recommendation would be greatly appreciated.
Old 05-29-15, 07:05 PM
antis
antis's Avatar
I painted the trans with high heat engine primer and aluminum paint.
Old 05-29-15, 09:08 PM
antis
antis's Avatar
Brought her in for the night.
Old 06-02-15, 06:20 PM
antis
antis's Avatar
Installed the ATI damper that I picked up from Titan Motorsports.
Old 06-03-15, 08:45 AM
antis
antis's Avatar
Best thing to wake up to, FedEx ringing the doorbell bright and early.
Old 06-03-15, 10:51 AM
antis
antis's Avatar
More parts straight from Japan, JZX110 shifter housing and JZX100 R154 mount. I will be using is300 auto crossmember.
Old 06-04-15, 02:13 PM
antis
antis's Avatar
Thanks to JesLet who helped my out with some issues getting the jzx110 shifter housing to work with a Mk3 R154.
I didn't liked how only two bolts align with the extension housing, I'm sure someone who doesn't want to spend more money on this step it would work by getting really thin bolts with large washers and a nut as theres is space. I want a much cleaner look and would like to use all the bolts on the jzx100 r154 mount, I went the extra mile and purchased a jzx extension housing (not to be confused with the shift housing).
This is what neutral looked like on the Ralco shifter before getting straighten.
After getting straighten.
Old 06-06-15, 12:03 AM
Pwrdby2JZ
Pwrdby2JZ's Avatar
Build looks great. Im also going the aristo gte route but non vvti. How hard is it to wire the two harnesses together? Ill be using a aristo ecu with greddy piggyback
Old 06-06-15, 07:30 PM
antis
antis's Avatar
Thanks, I went a different route. I didn't need to merge the harness. I used the is300 GE harness. If you need to merge the harness and are unsure, I'd recomend you send them to tweak'd.
Old 06-10-15, 09:50 PM
antis
antis's Avatar
PROEFI 5 bar map sensor installed.
FID 2000
Fuel injector clinic dual -8 feeds and -6 return
Quick Reply: IS300 Aristo VVTI Build
