Replace 8" Mark Levinson sub woofer - 2009 ISF
My 8" Mark Levinson Sub has blown. Any idea what would be a good replacement? Also how to remove it?
Thank so much.
Thank so much.
Pull your back seats out to get access to the sub:
https://www.clublexus.com/forums/is-...rear-deck.html
Best replacement is a box in the trunk and add a dedicated amplifier. If I recall correctly, you'll want to avoid using the stock subwoofer signal, since it wont power an aftermarket sub, and it also has an extremely conservative low frequency cutoff (~50hz?) -- you'll want to tap a signal in the rear door and run that to your amp instead.
Wrong section to post this in, but use the search function, there are numerous threads on this!
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
