Build Threads Details on Club Lexus 2GS owner vehicles
xHyaku's UZS160: The Battleship
Old 12-18-15, 02:43 PM
  #61
black_LS
black_LS's Avatar
^ What are you on about?
xHyaku, I've attached the diagnostics pages for your codes in case they help.
File Type: pdf
File Type: pdf
Old 12-18-15, 03:54 PM
  #62
xHyaku
xHyaku's Avatar
Originally Posted by SoCal Cyco
Go to http://aprperformance.com/racing-pro...ind-splitters/, read instructions, send them template and money, GTFO of my thread.
Really rude man...
Lol. I don't tolerate people coming into my thread and rambling about unrelated ****. I was actually nice enough to guide him to the right place.
Thanks man! But I already have all this information. . Kinda hard to wire up a car without the right info.
Old 12-18-15, 06:49 PM
  #63
xHyaku
xHyaku's Avatar
Ah, sucks about the P/N switch. If you're interested in getting rid of the speed sensor code, a diff mounted trigger wheel may work: http://wilbo666.pbworks.com/w/page/7...rigger%20Wheel
Maybe I missed it, but which "gear" are you running it in?
Sorry, I forgot to reply to this post. Vehicle runs in D. ECU uses the assumed D signal to adjust the air fuel ratio.
Old 12-20-15, 08:44 PM
  #64
black_LS
black_LS's Avatar
What about the front trans speed sensor? Did it ever throw a code for that?
Old 12-24-15, 11:52 PM
  #65
xHyaku
xHyaku's Avatar
No code is thrown for the front. Makes me wonder what else the logic looks at for the rear.
Interior pic because I'm bored. Swapped out my TRD **** back to the bubble flower ****. The extra leverage sure is nice.
Old 12-25-15, 11:49 AM
  #66
Revive
Revive's Avatar
...It's your fault I just bought an r154 to go in my na-t. Hope you don't mind if I hit you with a few questions through the process. lol
Love your build man. Thanks for sharing!
Old 12-25-15, 02:51 PM
  #67
xHyaku
xHyaku's Avatar
Originally Posted by Revive
...It's your fault I just bought an r154 to go in my na-t. Hope you don't mind if hit you with a few questions through the process. lol
No worries, shoot me a PM anytime.
Old 01-18-16, 01:00 AM
  #68
AdamP
AdamP's Avatar
Good stuff this thread covers alot of info I was looking for. Was using a circle saw for the master cylinder a pita?
Old 02-01-16, 01:21 AM
  #69
PureDrifter
BahHumBug
PureDrifter's Avatar
Any updates on what you plan to do to resolve the remaining codes?
Been following this a while, keep it up
Old 02-03-16, 06:30 PM
  #70
lexgs30002
lexgs30002's Avatar
dang nice build keep it up.
Old 02-07-16, 08:42 AM
  #71
xHyaku
xHyaku's Avatar
That's good to hear! Trying my best to document the swap. Cutting through the firewall was made easy because my drill has a swivel head and it's pretty compact making it fit in the engine bay pretty easy.
I haven't had the motivation to work on the car or drive it (until recently). The only code I would be able to fix is the rear speed sensor. Probably just tie it to the abs and call it a day. As for the NSS, only way is to go with a '98 ecu and keys if I wanted to keep all functionality of the obd system.
Thanks! Will try, it's been rough trying to keep my motivation up.
Finally taking her out to the track on Feb 27. I registered for TRD Cup, a new Time Attack series in SoCal for all Toyota vehicles.
www.trdcup.com
Still needs a lot of prep done! Stay tuned.
Old 02-11-16, 10:31 PM
  #72
Revive
Revive's Avatar
How do you like the shifter placement overall? I'm about to start pulling my auto and measuring (as soon as I find some of that fabled motivation). From the pics your seems to be in a pretty comfortable position.
Old 02-12-16, 07:12 AM
  #73
xHyaku
xHyaku's Avatar
With my 4" extension, the mk3 shifter placed 2nd, 4th, and R too far back to my liking. My arm kept hitting my bucket seat when shifting.
I then had to cut and weld the s3 shifter (it was painful!) to straighten it out. I left a 2° bend going rearwards and now it's very comfortable and a pleasure to drive.
Here's how it sits in Neutral. Don't mind the rags, slowly working on a cover
If you leave the mk3 bends, maybe a 2.5" extension would be good, 4" is def too much for the stock bend.
Old 02-21-16, 02:31 PM
  #74
xHyaku
xHyaku's Avatar
Boring update, been putting this off for a couple months.
Replaced with a reman Denso. Old hoses and connectors are the worse, cracked every single one I touched :T
Drained and filled the R154 with MT90. Also rerouted some wiring. I need to find a way to head over to Danny's shop to get an alignment before Saturday's track day...hmm.
Old 03-03-16, 06:33 AM
  #75
xHyaku
xHyaku's Avatar
Track day was a blast on Saturday! Clocked an awesomely slow time of 1:37 at Streets of Willow, counter clockwise configuration. Not bad steering this 1 ton car on ****ty tires! My group was running an average of 1:34 in sports cars on summer tires. I'm curious how the GS would do with 255 RS3s on all 4 corners.
It was a workout keeping the weight of the car in check. I would have to brake earlier or cruise the main straights to prevent brake fade.
At the tires limit, the GS was predictable. A little throttle on exit and she was happy to play! So much so, I got in trouble for sliding everywhere!
Sadly no video, got some boring straight away shots though...
Name:  Feb-27-2016-ExtremeSpeed%20-%20Green%20-%20Turn%207%20-%20WS__5520_Feb2716_by_CE-CaliPh.jpg
Name:  Feb-27-2016-ExtremeSpeed%20-%20Green%20-%20Turn%202%20pan%20-%20WS__3673_Feb2716_by_CE-.jpg
Name:  Feb-27-2016-ExtremeSpeed%20-%20Green%20-%20Turn%20one%20inside%20-%20WS__3564_Feb2716_b.jpg
Quick Reply: xHyaku's UZS160: The Battleship
